Old 21-01-2007, 04:29 PM   #1 (permalink)
Google Bot
Pathik's Avatar
Unhappy FC 6 Problem
i just got a copy of fc6.... and i installed it on a frends pc... it worked absolutely fine...
now wen i installed it on my pc he installation went fine but now wen i boot into fc6 i get a black blank screen.... wats the prob????
graphic drivers???
pls help
Pathik is offline
Old 21-01-2007, 04:46 PM   #2 (permalink)
18 Till I Die............
Default Re: FC 6 Problem
Post your config plz.
http://www.bash.org/?258908
mehulved is offline
Old 21-01-2007, 05:30 PM   #3 (permalink)
Google Bot
Pathik's Avatar
INTEL P4 2.4ghz...
Asrock 845gv mobo... onboard 64mg gfx..
512 mb ddr ram...
LG 14" CRT.......
wat else???
hey tyf pls help me yaar... i want to run fc6 very desperately...
Pathik is offline
Old 21-01-2007, 05:45 PM   #4 (permalink)
I don't see anything that can go wrong here. Do you have a graphics card? Does it throw an error of 'Frequency out of range' or such?
Do some other distros work?
mehulved is offline
Old 21-01-2007, 05:53 PM   #5 (permalink)
Google Bot
Pathik's Avatar
nope no gfx card....
well ubuntu 6.06 didnt work...
mandriva 2006, suse 10.1, fc2, ubuntu 6.10 worked....
ny soln???
Pathik is offline
Old 21-01-2007, 06:20 PM   #6 (permalink)
Check if this helps http://mm.gnu.org.in/pipermail/linux...13/046377.html
Press ctrl+alt+F1 or F2 to go to a virtual terminal. type lspci there. Is the output similar to one given there. If not, try the solution given in the last line.
mehulved is offline
Old 21-01-2007, 06:27 PM   #7 (permalink)
Google Bot
Pathik's Avatar
k thx i ll try this... btw mandrake 10.1 worked perfectly in my pc...
Pathik is offline
Old 21-01-2007, 06:46 PM   #8 (permalink)
the problem i read so far is that FC6 was released in a hurry while mandriva has done it perfectly. especially the device driver settings and the desktop effects and also the i586/i686 issue is totally void in mandriva. so some systems might have problems with the iso of FC6. though , i dint face this problem. try to some how get the updates of fedora and install it either after the actual installation or somehow infuse it with the old iso, if possible or get an updated iso. that should also fix u tons of problems which i solved one by one off late!
/legolas
legolas is offline
Old 21-01-2007, 06:47 PM   #9 (permalink)
Google Bot
Pathik's Avatar
tyf.. Wen i open the virtual terminal i cant type nything in it.. I can just see the text that comes during the loading.. Its enlarged.. And the last line is ..mount:cannot mount block device /dev/hd... I cant read the part after hd
Pathik is offline
Old 21-01-2007, 06:52 PM   #10 (permalink)
Which vertual terminal? Try ctrl + alt + F2 or F3 or even F4. I don't know about FC properly. I guess one should be free.
mehulved is offline
Old 21-01-2007, 07:24 PM   #11 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
My config is
P4 2.4 GHz,
512 MB RAM
intel D845GVSR
should FC6 work flawlessly on my computer???
n00b forever...
~Phenom~ is offline
Old 21-01-2007, 07:49 PM   #12 (permalink)
Google Bot
Pathik's Avatar
ctrl -alt-f1
Pathik is offline
Old 21-01-2007, 08:20 PM   #13 (permalink)
Wire muncher!
infra_red_dude's Avatar
problem wid physical connection of the hdd?? or mebbe some error during installation??? looks like that.... try to load linux in console mode, instead of gui while booting from the boot loader.
__________
Originally Posted by ~Phenom~
My config is
P4 2.4 GHz,
512 MB RAM
intel D845GVSR
config is fine enough to run fc6. but dunno if u can enable compiz wid the default drivers on 845. some 845 user will be able to help u wid compiz. otherwise if fine enough.
Last edited by infra_red_dude; 21-01-2007 at 08:20 PM. Reason: Automerged Doublepost
infra_red_dude is offline
Old 21-01-2007, 08:26 PM   #14 (permalink)
Google Bot
Pathik's Avatar
@ phenom .. Cant say.. Fc6 has problems recognising hardware... @ infra.. I ll try that too
Pathik is offline
Old 21-01-2007, 10:13 PM   #15 (permalink)
pathiks, can you check which PATA controller you have? A person on ILUG-BOM says he had a problem with FC6 and his PATA controller - JMicron.
Here's the thread http://mm.ilug-bom.org.in/pipermail/...15/057449.html
His username on the forum is daj. In case you need to contact him, you can get his e-mail address from there.
mehulved is offline
Old 21-01-2007, 10:18 PM   #16 (permalink)
Wire muncher!
yeah cud be prob wid controller or mebbe a southbridge or controller driver problem.
Old 21-01-2007, 10:45 PM   #17 (permalink)
Google Bot
Pathik's Avatar
hey but the installer recognized my hdd immediately.. Unlike in the case of daj.. I installed it using the isos on my hdd.. Neways how do i check wich pata controller i hv?? Afaik asrock has its own controller
Pathik is offline
Old 21-01-2007, 11:06 PM   #18 (permalink)
Just another linux lover.
subratabera's Avatar
Try this...
1)Boot from a live cd (Ubuntu 6.10, knoppix etc.)
2)Mount your Fedora Installation partition.
3)Open the file /etc/X11/xorg.conf (Fedora)
4)Now search for this section...
Section "Device"
Identifier "Intel Corporation 82810E DC-133 CGC [Chipset Graphics Controller]"
Driver "i810"
EndSection
5)Change "i810" (different in your case) to "vesa"
6)Reboot
Today is a most unusual day, because we have never lived it before; we will never live it again; it is the only day we have.
(Registered Linux User #432737 - subratabera.blogspot.com)
subratabera is offline
Old 21-01-2007, 11:10 PM   #19 (permalink)
It seems like a problem with the hard drive. As infra_red_dude pointed out, I had missed it completely
So, one or more of the partition isn't mounting. Thus everything is stuck. Maybe it's the / partition.
mehulved is offline
Old 21-01-2007, 11:11 PM   #20 (permalink)
Google Bot
Pathik's Avatar
hey thanx bro.. I ll do it tomo.. Can u explain wat exactly it does??
Pathik is offline
Old 21-01-2007, 11:42 PM   #21 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
@ pathiks , I tried installing FC6 using virtual Boot loader ie through CD ISO images . FC6 installed successfully , but when i booted into it for the first time , just a blank black screen appeared and nothing happened. Should I now try to reinstall with Burning those images into DVD using the tut of this forum. Or it will be a waste of time and I should not think about it ????
n00b forever...
~Phenom~ is offline
Old 21-01-2007, 11:48 PM   #22 (permalink)
Google Bot
Pathik's Avatar
hahaha phenom..Both of us hav exactly the same problem.. Btw wats ur system config?? And dont bother to convert those cds to dvd,. Wont make ny diff.. Btw wich oses u using currently??
Pathik is offline
Old 21-01-2007, 11:55 PM   #23 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
my sys config: p4 2.4 ghz
512 mb ram
intel d845gvsr mobo.
OS dual boot : xp sp2 and edgy
n00b forever...
~Phenom~ is offline
Old 22-01-2007, 12:03 AM   #24 (permalink)
Google Bot
Pathik's Avatar
even i hav a similar config.. Btw r u keepin edgy n fc6 both or one of them.. And post here if u find a soln..
Pathik is offline
Old 22-01-2007, 12:09 AM   #25 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
when I had that problem( around 1 month back) , I deleted my linux ( ie fc6) , I was not having edgy installed that time.
I cuurently just have XP SP2 ( which i use occassionally) and edgy.
n00b forever...
~Phenom~ is offline
Old 23-01-2007, 01:25 AM   #26 (permalink)
Google Bot
Pathik's Avatar
i ll try subratabera s method n tell u.. I think it ll work.. Read the how_to editing xorg.conf sticky.. It shd help
__________
hey i m not able to access my ext3 drive in wich i installed fc6 thru windows... IFS... why is it so??? i get a msg that the drive isnt formatted...
Pathik is offline
Old 23-01-2007, 03:53 AM   #27 (permalink)
Do you have some tools installed to read ext3 from windows? Otherwise windows won't recognise the drive surely.
mehulved is offline
Old 23-01-2007, 10:02 AM   #28 (permalink)
Google Bot
Pathik's Avatar
Yaar i know that.. I hav IFS wich reads ext2 n ext3,. It used to read my drive wen ubuntu 6.10 was installed but not now..
Pathik is offline
Old 06-02-2007, 02:10 PM   #29 (permalink)
help plz!!!
i have 6 cd images of fedora core 6 , and i want to convet it on a autorun DVD .plz anybody give me the way to do this . .... plz
michel.shan is offline
Old 06-02-2007, 05:09 PM   #30 (permalink)
Google Bot
Pathik's Avatar
see this link
Make DVD iso from CD isos of Fedora Core 5
btw the 6th cd is jus a rescue cd so leave it out...
Pathik is offline
