Old 17-01-2007, 10:18 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default GUI matlab not visible. help pls!
Hi guys,
i installed matlab for linux in my FC6 machine and it was working fine. But i just updated my graphics card driver from the default open source nv driver to nvidia driver (downloaded from the website) inorder to enable the visual effects (vobbling and stuffs). now, when i open matlab, i get a screen with only the close, minimise and maximise button visible and all the others inside.,... they are not rendered(visible).... if i click alt+f, then the file menu opens... except that i couldnt see it. and similarly any thing... no command window, workspace nothing... its opened but nothing is shown... does any1 know how to rectify the problem... i even tried reinstalling matlab. it dint fix the problem...
thks,
legolas.
legolas is offline
Old 17-01-2007, 10:27 PM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: GUI matlab not visible. help pls!
Can u please tell me from where u installed it? I need it too!
Neways for ur problem, try deleting the matlab directory hidden in ur home folder (if there's any).
mediator is offline
Old 18-01-2007, 04:59 PM   #3 (permalink)
thks i solved the issue it was a compiz related issue!
/legolas
legolas is offline
Old 18-01-2007, 05:05 PM   #4 (permalink)
18 Till I Die............
What was the solution? It might help somebody else
http://www.bash.org/?258908
mehulved is offline
Old 18-01-2007, 05:26 PM   #5 (permalink)
Yes, that is right. here goes my solution when matlab opens but doesnt show its GUI.
open the terminal, log in as root using
su
followed by password
then using ur favourite editor, open a file in this path
for ex:
gedit /usr/local/bin/matlab-c (matlab-c is the file name u ll be using to open matlab. u can use any name of ur choice... but dont use matlab as it already exists)
copy these two lines, hit enter, then save it.
#!/bin/sh
AWT_TOOLKIT=MToolkit matlab
now u can type matlab-c from anywhere to execute matlab. remember to set the permissions for the matlab-c for non-root user using chmod command before executing.
good luck,
legolas
legolas is offline
Old 18-01-2007, 09:46 PM   #6 (permalink)
String Phreak
mediator's Avatar
Thanx for sharing ur solution. Ur experience will come in handy!
mediator is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/open-source/46674-gui-matlab-not-visible-help-pls.html
Thread gui matlab | ????? ????????? ????? - ??? ????? ????? ???? | BoardReader This thread Refback 13-10-2010 11:07 PM
