| Forum |
#1 (permalink) |
i had made 1 web service which returns the html containing <script>alert('hello')</script> after getting response from server i had assigned the responseText to one div's innerHTML but it not working so how can i use this script to work it out. i need it for 1 application which registers the images in dragable content, so if no way to run this script in this way then is there any way to make it?? Thanks in advance..
If you want the best, you have to vote for the best V.I.P.U.L.:= Vigilant Individual Programmed for Ultimate Learning |
#3 (permalink) | |
var imagePath="../../Common/Images/Icons/bar.gif";
var http_request = false;
var resid;
var lid;
function makeRequest(url,param,type,loading,result)
//makeRequest("http://xyz.com","name=abc","POST/GET","LoadId","ResId")
resid=result;
lid=loading;
document.getElementById(lid).innerHTML="Loading...<br><img src='" + imagePath + "'><br>";
if (window.XMLHttpRequest)
{ // Mozilla, Safari,...
http_request = new XMLHttpRequest();
} else if (window.ActiveXObject) { // IE
http_request = new ActiveXObject("Microsoft.XMLHTTP");
else
alert("Your browser not support XMLHTTPRequest.");
http_request.onreadystatechange = alertContents;
http_request.open(type, url);
http_request.setRequestHeader("Host","localhost");
http_request.setRequestHeader("Content-Type","application/x-www-form-urlencoded");
http_request.send(param);
function alertContents() {
if (http_request.readyState == 4) {
if (http_request.status == 200)
document.getElementById(resid).innerHTML='';
document.getElementById(resid).innerHTML=http_request.responseText;
document.getElementById(lid).innerHTML="";
} else {
alert('There was a problem with the request.');
just response.write("<script>alert('Hello')</script>") but it prints <script>alert('Hello')</script> in given DIV not the script itself Thanks
#4 (permalink) |
In Pursuit of "Happyness"
The document.getElementById() takes in a string as a paramater..
So it should be document.getElementById("resid").innerHTML=''; Notice the quotes? |
#5 (permalink) | |
i had just used script.aculo.us its gr8 man........ it works 4 me................... btw Thanks..
| Bookmarks |
| Thread Tools | |
| Display Modes | |
