Old 04-01-2007, 06:41 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
eagle_y2j's Avatar
Default SUSE not able to detect LG Studiowork 500G monitor...
Suse 10.2 is not able to detect my LG Studiowork 500G monitor .. Any one of u know the settings for Studiowork 500G monitor i.e Display size X-axis ,Y-axis and horizontal and vertical frequencies ...and any other seting for maual set up ..
TIA
Registered LINUX USER #438929
eagle_y2j is offline
Old 04-01-2007, 07:00 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: SUSE not able to detect LG Studiowork 500G monitor...
The nice thing in SuSE is the ability to run YasT2 even in the command line mode. So all you have to do is
1. Wait for your login screen to show up
2. If you see a graphical login press ctrl+alt+F1 to get a text login screen
3. Login as root
4. At prompt type yast and press enter
5. Now you will get YaST2 control panel like you do in the normal GUI mode, except that here your mouse will not work, you will have to navigate using the following keys, Tab to toggle between the left and right panels, arrow keys to move up and down in those panels, enter key to start/open any service, and spacebar to tick/untick
6. Go to Hardware-> Graphics card and monitor
7. SaX2 will open, and in that you can autoprobe your monitor and configure it. First see if it detects your monitor correctly, many a time the detection is simply wrong. Don't fiddle with the frequencies, try changing the aspect ratios and colour depths. And lastly, test the configuration before you save.
All the best
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 04-01-2007, 08:56 PM   #3 (permalink)
eagle_y2j's Avatar
3. Login as root
All the best
thankx for helping me but sir my problem is little bit wired type sometimes I m able to login Suse in GUI mode and sometimes my linux box is showing be black screen of death . Right now I m using GUI mode to post this....so I think I can skip 5 steps .
I tried changing my monitor setting here only(SaX2) but i don't know exact settings .
Can some1 provide with me settings like Display size X-axis ,Y-axis and horizontal and vertical frequencies for my monitor
Old 04-01-2007, 09:06 PM   #4 (permalink)
18 Till I Die............
Check the manual that came with your monitor or look it up on LG's site.
http://www.bash.org/?258908
mehulved is offline
Old 04-01-2007, 09:07 PM   #5 (permalink)
Tech Geek's Avatar
can anyone tell me the dimensions for LG Studioworks 563N
I don't have the manual with me
Tech Geek is offline
Old 04-01-2007, 09:13 PM   #6 (permalink)
Arsenal_Gunners's Avatar
here see if this helps
http://www.ciao.co.uk/LG_563N__5392631
Arsenal_Gunners is offline
Old 04-01-2007, 09:17 PM   #7 (permalink)
Tech Geek's Avatar
Nope this is not i wanted
i wanted the dimensions of the desktop which we chage though the buttons on the monitor
i have googled a lot
useless
Old 04-01-2007, 09:23 PM   #8 (permalink)
eagle_y2j's Avatar
i lost my manual and LG's site is not having ny info bout my problem LG 500G
Old 04-01-2007, 11:38 PM   #9 (permalink)
desertwind's Avatar
Vertical Refresh Rate - 30-54
Horizontal Refresh rate - 50 - 120
Max Resolution - 1024x768 @ 60 Hz
Usually this much is enuff for configuring monitors. Hope this helps.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/open-source/45658-suse-not-able-detect-lg-studiowork-500g-monitor.html
Thread SUSE not able to detect LG Studiowork 500G monitor... | Digit Forum | BoardReader This thread Refback 07-08-2010 02:38 PM
