Old 25-12-2006, 01:11 PM   #1 (permalink)
Default Problem loading Xserver
Hi guys,
I ve got ubuntu alternate cd and installed ubuntu successfully.The problem is i am unable to get into X Gui.i tried to edit Xserver-xorg and set the graphics driver to nv as i am having onboard geforce 6100.even then i got an error while booting into x by giving startx.it gives an error saying Invalid fontpath.
please help me.
Thanks,
Jaga
catchjaga is offline
Old 25-12-2006, 01:16 PM   #2 (permalink)
18 Till I Die............
Default Re: Problem loading Xserver
Follow this http://ubuntuguide.org/wiki/Ubuntu_E...r_.28NVIDIA.29 or http://ubuntuguide.org/wiki/Ubuntu_E...r_.28NVIDIA.29 to install nvidia drivers and see what happens.
http://www.bash.org/?258908
mehulved is offline
Old 26-12-2006, 10:48 AM   #3 (permalink)
Hi tech,
the problem is i dont have net connection in my home.however i tried to install the one coming with the cd.I copied the .deb file to my windows partition and i accessed the partion using mount .i was able to see those files however.when i gave sudo apt-get install <file name>
it says unable to find such file.So i tried to copy from that partition even that didnt work.
also i have a doubt whether I should set the graphics driver to nv or vesa.
thanks,
Jaga
Old 26-12-2006, 07:42 PM   #4 (permalink)
Beneath The Eyelids
The Outsider's Avatar
dunno bout your problem but installing deb file from windows partition won't work, copy the file to your root partition.
partitions should be automatically mounted check /media
The Outsider is offline
Old 26-12-2006, 07:47 PM   #5 (permalink)
Use dpkg to install a deb file that you've downloaded
sudo dpkg -i <filename>
mehulved is offline
Old 27-12-2006, 03:18 PM   #6 (permalink)
Thank u man i ll try this
