Re: Sound problems on OpenSUSE 10 on Sony Vaio c15
thanks for the reply. was suse
__________
Thanks for the reply.was suse10.2 given in any previous digit or chip cd? As for testing the sound card in yast,well i did.But once again no sound.although it is evident that my sound card has been recognised.nothing is muted,i have checked and rechecked.Also can you tell me what is the path for the kernel source tree in suse 10.1.the latest version of alsa needs this to install.this is what the install file says:
Kernel Source Tree
On 2.4/2.6 kernels, the location of the kernel source tree is
parsed automatilly from the running kernel.
If it's not in the standard place, specify the path via
--with-kernel=<kernel_directory>.
On 2.6 kernels, the build directory has to be given via
--with-build=<kernel_build_dir> option additionally, too.
The difference between insanity and genius is measured by success
Reason: Automerged Doublepost
