Old 20-12-2006, 01:57 PM   #1 (permalink)
Fedora User
LEARNER_LEARNER's Avatar
Post help guys....?
Hi guys,i was installing Kino(videoEditor software) but i'm not able 2 install from this error msg
[root@localhost ~]# yum -y install kino
Loading "installonlyn" plugin
Setting up Install Process
Setting up repositories
http://macromedia.rediris.es/rpm/repodata/repomd.xml: [Errno 12] Timeout: <urlopen error timed out>
Trying other mirror.
Error: Cannot open/read repomd.xml file for repository: macromedia
i'm waiting ur reply bro.help me please
LEARNER_LEARNER is offline
Old 20-12-2006, 02:29 PM   #2 (permalink)
desertwind's Avatar
Default Re: help guys....?
try this
yum -y install kino --disablerepo=macromedia
BTW, why are you working as root ? Use sudo instead.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 20-12-2006, 02:47 PM   #3 (permalink)
Fedora User
no desertwind i not work in root ,i always work in [root@localhost learner].is it right 4 me?.
ThanX 4 help bro
Old 21-12-2006, 10:08 AM   #4 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Lightbulb Re: help guys....?
ThanX 4 help bro
Logging in root is a bad practise because in case you delete some system files, you are doomed!! So, always log in as a normal user. In case you need to install any application, go to the terminal and type 'su'(without quotes). You will be prompted for a password. Enter the root's password here. Install the necessary apps and type exit twice to close the terminal. To install kino, follow the steps which desertwind has suggested.
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 21-12-2006, 01:33 PM   #5 (permalink)
GaurishSharma.com
gary4gar's Avatar
ThanX 4 help bro
then if u are stuck with a malware or u hacked don't complian that linux insn't secure as it your mistake, u are comprising security of ur box.
gary4gar is offline
