Hi guys,I was installing K3b from this command .what is problem pls help..
file name is:-k3b-0.12.17.tar.bz2
[root@localhost K3b]tar -xjvf k3b-0.12.17.tar.bz2
and change to the created directory:
cd k3b-0.12.17
[root@localhost k3b-0.12.17]# ./configure
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking for -p flag to install... yes
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for kde-config... /usr/bin/kde-config
checking where to install... /usr (as returned by kde-config)
checking for style of include used by make... GNU
checking for gcc... no
checking for cc... no
checking for cl... no
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
[root@localhost k3b-0.12.17]# make
make: *** No targets specified and no makefile found. Stop.
[root@localhost k3b-0.12.17]# su -c "make install"
make: *** No rule to make target `install'. Stop.
I'm waiting 4 ur reply bro
