Old 17-12-2006, 11:06 AM   #1 (permalink)
desmond_315's Avatar
Default Setting up an internet connection in linux
hey guys....this might seem real dumb to ul expert but im real new to linux.. have just installed fedora core 5 on my comp... its been a bit difficult learning cause i have gota switch bet my windows n linux for tutorials n then to practise wat ive learnt.. that y i need ur help in settin an internet connection in linux.. i have a broadand connection with my telephone company n am using a Dlink ADSL router ( DSL-502T).. please help..thanks.
desmond_315 is offline
Old 17-12-2006, 01:20 PM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: Setting up an internet connection in linux
1. System => Administration => Network
2. Fill ur root password
3. Activate the network device i.e eth0, if its not there then add it
4. Fill in the DNS entries
5. After all set edit the eth0 and make it static ip there with adress = "192.168.1.2" , subnetmask="255.255.255.0" and gateway="192.168.1.1"
6. Open terminal "ping 192.168.1.1"
7. If alls well, ur blessed!
8. try "ping yahoo.com"
9. If alls well then ur connection is ready else there is something wrong with connection at hardware level or dns settings.
Also since ur a newbie refer to this Linux: Making Life Easy and other threads in stickies.
mediator is offline
Old 17-12-2006, 01:27 PM   #3 (permalink)
i do not have a LAN card.. connectin the router via the USB.. wat type of connetion n wat adapter to i select?
Old 17-12-2006, 02:05 PM   #4 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
try adsl-setup in terminal , easiest way around.
n00b forever...
~Phenom~ is offline
Old 17-12-2006, 02:48 PM   #5 (permalink)
String Phreak
mediator's Avatar
I'll advice to buy a LAN card then, coz ROuter through USB is still very cumbersome and may not work.
mediator is offline
Old 17-12-2006, 02:58 PM   #6 (permalink)
left this forum longback
praka123's Avatar
USB router support is near to Nil.try ur luck.buy one cheap lan card around Rs 100?
praka123 is offline
Old 17-12-2006, 03:52 PM   #7 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
USB will give u lot of problems on linux , buy lan card.
n00b forever...
~Phenom~ is offline
Old 17-12-2006, 03:57 PM   #8 (permalink)
Case Mod - 60% ||||||----
spynic's Avatar
USB drivers are not available for 502T (linux).. get a lan card..
spynic is offline
Old 17-12-2006, 04:25 PM   #9 (permalink)
18 Till I Die............
Also the connection via a LAN card is more stable in any OS than via USB. The reasons for it are posted somewhere in the forum but I am too lazy to search for it now.
http://www.bash.org/?258908
mehulved is offline
Old 21-12-2006, 12:22 PM   #10 (permalink)
k guys ill do that...buy the Lan card.. ne one in particular thats good?
Old 21-12-2006, 01:25 PM   #11 (permalink)
GaurishSharma.com
gary4gar's Avatar
any card of any make will do but if u still want a brand try realtek card they are very good u should get it aroung 175rs
gary4gar is offline
Old 22-12-2006, 01:31 AM   #12 (permalink)
praka123's Avatar
I've heard even USB drivers for modem-a-routers are not good even for windows -that it sometimes affects the stability of broadband connxn.so BB via Lan Card is good imho.brands? may be dlink ones?
praka123 is offline
Old 22-12-2006, 02:01 AM   #13 (permalink)
String Phreak
mediator's Avatar
Exclamation Re: Setting up an internet connection in linux
What u have heard is absolutely correct. Its a real pain when Internet USB connections break frequently.
mediator is offline
