Hi guys,i,m installing shutdown software "kshutdown-0.9.1beta.tar.bz2" through this command "tar xvfj nameoffile.tar.bz2" nd successfully decompress.Then i type in terminal " ./setup" nd then i pressed "I" key start but saying "Setup: Configuration failed!".Please help me..
KShutDown 0.9.1beta Setup
Compilation and Installation
[i] Install (./configure --prefix=/home/desktop, make, kdesu -c "make install")
[p] Change installation directory (prefix)
[f] Disable fast compilation
Documentation and License
[n] What's new? (q - quit)
[l] License (GNU GPL)
[r] Readme
[q] Quit
http://kshutdown.sourceforge.net
Setup: Configuring with '--prefix=/home/desktop --enable-final'...
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking for -p flag to install... yes
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for kde-config... /usr/bin/kde-config
checking where to install... /home/desktop (as requested)
checking for style of include used by make... GNU
checking for gcc... no
checking for cc... no
checking for cl... no
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
Setup: Make sure you have installed the 'kdelibs-devel' package
which is required to compile any KDE application.
Press <Enter> to exit
