Old 09-12-2006, 12:41 AM   #1 (permalink)
baccilus's Avatar
Default Ubuntu 6.06 64bit hangs on shutdown !
Ubuntu refuses to shutdown. The 32 bit never had any such problem but this 64 bit is really buggy. It just freezes with a blank screen. system:
Intel P4 EMT64 2.66 GHz, 1GB RAM, Asrock 945 mobo.
Appreciate me now and avoid the rush!!
i5 2500K || 8GB DDRIII 1600 MHz RAM || Zotac GTX560Ti || Samsung 2233sw || Corsair GS600
baccilus is offline
Old 09-12-2006, 10:26 AM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: Ubuntu 6.06 64bit hangs on shutdown !
did u enabled root in Ubuntu?
OK. try CTRL+ALT+F1 to get a login prompt .then try:
/sbin/shutdown -h now
next time while getting grub menu.press kbd `e` to edit the kernel line remove the "quiet splash" in the line.view the error message while shutting down.post it here.
praka123 is offline
