Old 29-11-2006, 06:06 PM   #1 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Unhappy xine demuxer problem
I just installed on my FC5 (64 bit) distro. The installation went smoothly, but I'm getting an error. I'm posting the screenshot here. Please tell me what it means and how I can correctly.
Thanks in advance
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 29-11-2006, 07:05 PM   #2 (permalink)
18 Till I Die............
Default Re: xine demuxer problem
What file are you trying to open? Are all codecs installed?
http://www.bash.org/?258908
mehulved is offline
Old 29-11-2006, 07:13 PM   #3 (permalink)
phreak0ut's Avatar
Unhappy Re: xine demuxer problem
I get it as soon as I open Xine. I don't know if all the codecs are installed. How do I check it? Doesn't Xine install all the codecs?
Old 29-11-2006, 07:18 PM   #4 (permalink)
sariq
Posts: n/a
found this:
http://www.nabble.com/-xine-user--Gx...-t2657298.html
please use thumbnails for images instead of full images.
Old 29-11-2006, 07:19 PM   #5 (permalink)
No xine doesn't install all the plugins when installed. I don't know much about 64-bit OS's. But have heard that there are some problems with it. Maybe someone will help with that part.
mehulved is offline
Old 29-11-2006, 07:24 PM   #6 (permalink)
phreak0ut's Avatar
Talking Re: xine demuxer problem
Originally Posted by sariq
found this:
Thanks a lot for the link. I wanted to put a thumbnail, but I didn't know how to do that, So, I posted the whole screenshot there. Please do let me know how to post a thumbnail so that I can avoid that in the future. Also, can you please tell me which video player to use? I installed VLC player, but it closes immediately when I choose a file to play. Should I start a new thread on this or can you guys help me out here itself?
Old 29-11-2006, 07:28 PM   #7 (permalink)
Also issue command 'xine-check' in the terminal and see if that gives anything missing.
__________
For thumbnails upload the pic to some site like imageshack.us and it will give you a link to post in forums, use that.
mehulved is offline
Old 30-11-2006, 09:57 AM   #8 (permalink)
phreak0ut's Avatar
Red face Re: xine demuxer problem
Here's the output of that command.
Please be patient, this script may take a while to run...
[ good ] you're using Linux, doing specific tests
[ good ] looks like you have a /proc filesystem mounted.
[ good ] You seem to have a reasonable kernel version (2.6.18-1.2239.fc5)
[ hint ] Architecture is x86_64 (not intel), assuming there is no MTRR.
MTRR (Memory Type Range Registers) are used on intel CPUs to
control caching mechanisms for special memory ranges. There is
probably nothing like this on x86_64 CPUs...
press <enter> to continue...
[ good ] found the player at /usr/local/bin/xine
[ good ] /usr/local/bin/xine is in your PATH
[ good ] found /usr/local/bin/xine-config in your PATH
[ good ] plugin directory /usr/local/lib/xine/plugins/1.1.2 exists.
[ good ] found input plugins
[ good ] found demux plugins
[ good ] found decoder plugins
[ good ] found video_out plugins
[ good ] found audio_out plugins
[ good ] skin directory /usr/local/share/xine/skins exists.
[ good ] found logo in /usr/local/share/xine/skins
[ good ] I even found some skins.
[ good ] /dev/cdrom points to /dev/hda
[ good ] /dev/dvd points to /dev/hda
[ good ] DMA is enabled for your DVD drive
[ good ] found xvinfo: X-Video Extension version 2.2
[ good ] your Xv extension supports YV12 overlays (improves MPEG performance)
[ good ] your Xv extension supports YUY2 overlays
[ good ] Xv ports: RGBA RGBT RGB2 YUY2 UYVY YV12 I420
_________
I used an imaging hosting site to hotlink that image which I have posted there. Next time, I'll just post the link
Old 30-11-2006, 01:30 PM   #9 (permalink)
ok atleast that part is clear.
mehulved is offline
Old 30-11-2006, 05:58 PM   #10 (permalink)
left this forum longback
praka123's Avatar
Post Re: xine demuxer problem
Originally Posted by phreak0utt
[i]Please be patient, this script may take a while to run...
x86_64 bit?so you r running 32 or 64 bit OS?
praka123 is offline
Old 30-11-2006, 07:26 PM   #11 (permalink)
He's got 64bit FC5 prakash, check his 1st post.
mehulved is offline
Old 30-11-2006, 07:39 PM   #12 (permalink)
praka123's Avatar
then there is some problem with running w32codecs dependent files na?may be checking /usr/lib/win32/ for files will help and what is *.mpv extension?
praka123 is offline
Old 01-12-2006, 11:15 AM   #13 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Yes, 64 bit distros have perennial problems with multimedia.
kalpik is offline
Old 01-12-2006, 09:00 PM   #14 (permalink)
phreak0ut's Avatar
Oops!! I thought I could squeeze the juice of my processor with the 64 bit edition as I still can't afford a 64 bit Windows Ed. Too bad. Probably I'll try something from 32 bit stables next time on Linux..
Old 01-12-2006, 09:24 PM   #15 (permalink)
JGuru's Avatar
You can install 32-bit Linux. It will work perfectly in a 64-bit Processor. That should solve your multimedia problems.
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
Old 01-12-2006, 09:50 PM   #16 (permalink)
64-bit computing is a while away still IMO. Maybe about 6 months max.
mehulved is offline
Old 01-12-2006, 10:45 PM   #17 (permalink)
praka123's Avatar
chroot soltns are available for running multimedia things on 64bit,but if u r adventerous that i mean!
praka123 is offline
