I just purchased a 1 gb transcend jetflash drive. Works fine in windows and in linux. But windows has a safely remove hardware option. How do we do that in linux?
I tried running KwikDisk, and the system tray icon gives the following option at the bottom. '/media/usbdisk',
but when i click on that to unmount, it gives an error saying
called: umount /dev/sdb1
umount: /dev/sdb1 is not in the fstab (and you are not root)
What can I do. Is it ok to simply unplug the drive? --waiting with the drive in the drive in the usb port ---
