Old 18-11-2006, 11:53 PM   #1 (permalink)
blackleopard92's Avatar
Default 64 bit linux does not mount.
well, i had a hard disk faliure on the disk on which Linux was installed.i had ubuntu 32 bit installed.after fixing MBR, i decided to install ubuntu 64 bit as i wanted to harness the power of my 64 bit cpu.(AMD athlon 3000+)
however, when i select start or install option in live CD, the booting stops at mount( the 2nd process)
32 bit installation runs fine, but i wanted 64 bit.
can anyone help?
blackleopard92 is offline
Old 19-11-2006, 09:13 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Post Re: 64 bit linux does not mount.
easy answer is to use ubuntu-64 alternate install cd.
otherwise with current 64-bit cd u need to try to modprobe the needed 64 modules using the last option in boot prompt.try to get what it shows
praka123 is offline
Old 20-11-2006, 12:03 AM   #3 (permalink)
Default Re: 64 bit linux does not mount.
Old 20-11-2006, 12:17 AM   #4 (permalink)
JGuru's Avatar
@Blackleopard92, Ubuntu 6.10 Alternate CD 64-bit is available.
Download it from here
It will solve your problem & install Ubuntu 6.10 using this Alternate CD.
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
