Old 18-11-2006, 03:35 AM   #1 (permalink)
Default help in installing ajunta in ubuntu
which packages are required to compile and install ajuntu on ubuntu?
currently it is giving this error during configuring ./configure
dheeraj@avtar:~/ide/ajunta/anjuta-2.0.2$ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for perl... /usr/bin/perl
checking for XML::Parser... configure: error: XML::Parser perl module is required for intltool
Dhiraj Thakur
thakur.dheeraj(@)gmail.com
Desi-Tek.com is offline
Old 18-11-2006, 04:08 AM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: help in installing ajunta in ubuntu
@dheeraj : Its anjuta! Just connect to the net, and command "sudo apt-get install anjuta"!
mediator is offline
Old 19-11-2006, 01:32 AM   #3 (permalink)
oh its name is little bit confusing! and mate thanx for help
Dhiraj Thakur
Old 19-11-2006, 08:49 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Desi-Tek.com - Whatever software you like and wish to use, first search it out under System > Administration > Synaptic. And only if it isnt present there, take the reins in your hand installing it the real way
Harsh J
www.harshj.com
QwertyManiac is offline
