Old 16-11-2006, 02:13 PM   #1 (permalink)
Default Mysql Help
How to use foreign key and store procedure in mysql? pls post the information with example.
Regards,
Dheeraj
Dhiraj Thakur
thakur.dheeraj(@)gmail.com
Desi-Tek.com is offline
Old 16-11-2006, 02:50 PM   #2 (permalink)
FooBar Guy
GNUrag's Avatar
Default Re: Mysql Help
Regards,
Dheeraj
First make sure that you are using MySQL 5.x series which now has support for Stored Procedures, Views and Triggers. For foreign keys make sure that your tables are using InnoDB engine.
it wont be wise of us to create examples for you and post here. Please do your homework first, let us know where you are stuck, and then ask.
http://web.gnuer.org
GNUrag is offline
Old 16-11-2006, 03:06 PM   #3 (permalink)
actually i know how to create view, sp, trigger in ms sql, is it same in mysql? or does it has any syntax difference?
Dhiraj Thakur
Old 16-11-2006, 03:36 PM   #4 (permalink)
FooBar Guy
GNUrag's Avatar
cool, if you already know SQL, then just head over to official MySQL documentation.
read this and try to make sense of it.
http://dev.mysql.com/doc/refman/5.1/...eign-keys.html
http://dev.mysql.com/doc/refman/5.1/en/views.html
http://dev.mysql.com/doc/refman/5.1/...rocedures.html
http://dev.mysql.com/doc/refman/5.1/en/triggers.html
there is almost no syntax differences between various databases.
GNUrag is offline
Old 27-11-2006, 12:24 PM   #5 (permalink)
bukaida's Avatar
Thumbs up Re: Mysql Help
check this out.
http://www.informit.com/articles/art...&seqNum=8&rl=1
Desktop: P-IV 2.4GHz, 512MB DDR, 865GBF Mother Board,
G-Force 5200FX, 17" Samsung flat, WinXp with SP2,
Kaspersky Internet Security 2009.
Laptop:LENOVO 3000 C100 D7 lappy with 2GB DDR2.
bukaida is offline
