Old 15-11-2006, 09:54 AM   #1 (permalink)
bukaida's Avatar
Angry Help installing GD library
I am using PHP 4.4.0 with apache 2 under winxp(sp2). Now I want to install gd library support for php. I couldnot find a decent instruction anywhere on how to install it under windows platform.From the Zip binary I have downloaded, i have copied the php_gd2.dll in my c:\php directory and also to
windows\system32 directory. I have changed the php.ini file to include
the extension directory and uncommented the extension module that corresponds to php_gd2.dll. But still it is not working.I am including a copy of my php.ini for your inspection.please help.
Desktop: P-IV 2.4GHz, 512MB DDR, 865GBF Mother Board,
G-Force 5200FX, 17" Samsung flat, WinXp with SP2,
Kaspersky Internet Security 2009.
Laptop:LENOVO 3000 C100 D7 lappy with 2GB DDR2.
bukaida is offline
Old 16-11-2006, 12:29 PM   #2 (permalink)
JGuru's Avatar
Default Re: Help installing GD library
@Bukaida, I think it should work!! Since you have placed the file php_gd2.dll in the
directory 'C:\PHP'. You have also made changes to the php.ini file to include the
extension.
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
Old 26-11-2006, 11:03 PM   #3 (permalink)
bukaida's Avatar
ya man, I have done a silly mistake.Instead of having the php.ini file in c:\windows , I put it in c:\windows\system32 (Which I discovered from phpinfo() ). Moving that file to c:\windows solved everything.
bukaida is offline
