Old 11-11-2006, 10:24 AM   #1 (permalink)
ECE0105's Avatar
Question Please help with Ubuntu Installation
Hi,
I have a P4 2.8 with an Intel D101GGC Mobo and a Seageate SATA (200GB) HDD.
I tried installing Ubuntu, but it says that there is No HDD Detected.
I currently have 7 partitions on the HDD and all in NTFS.
PLease help....
ECE0105 is offline
Old 11-11-2006, 10:35 AM   #2 (permalink)
left this forum longback
praka123's Avatar
Post Re: Please help with Ubuntu Installation
pls check ur BIOS settings w.r.t hdd setup.
praka123 is offline
Old 11-11-2006, 10:41 AM   #3 (permalink)
ECE0105's Avatar
Default Re: Please help with Ubuntu Installation
HDD is connected to SATA Port0.
DVD-/+RW is connected to IDE Primary as Master.
I also tried Linspire and Red Hat 9. with the same result. But I am using Windows XP and 2k3
ECE0105 is offline
Old 11-11-2006, 10:50 AM   #4 (permalink)
praka123's Avatar
ie wat i also have problem with my gigabyte 915 board also have BIOS setting which is very tricky to find out to set the hardddisk priority.so my advice is you should tinker with the settings which are related to harddisk settings.if u want i can post wat did with BIOS- when after a reboot
praka123 is offline
Old 11-11-2006, 12:51 PM   #5 (permalink)
18 Till I Die............
Which version of Ubuntu and Linspire did you try? Red Hat 9 won't detect SATA drives cos it's too outdated. There were no SATA drives at that time.
http://www.bash.org/?258908
mehulved is offline
Old 11-11-2006, 06:15 PM   #6 (permalink)
ECE0105's Avatar
Ubuntu 5.04 and Linspire 5.1
ECE0105 is offline
Old 11-11-2006, 06:18 PM   #7 (permalink)
They're outdated too and have no support for SATA that's why your hard disk isn't getting detected. You need something recent.
mehulved is offline
Old 11-11-2006, 06:40 PM   #8 (permalink)
praka123's Avatar
yeah.i though u've got latest ubuntu.you needs a 2.6 kernel based distro
praka123 is offline
Old 11-11-2006, 06:43 PM   #9 (permalink)
@ECE0105: search for LUG in your city and get the newest distro.
or you may order the free Ubuntu 6.06 which will hopefully detect your hardware.
dabster is offline
Old 12-11-2006, 01:07 PM   #10 (permalink)
ECE0105's Avatar
I have put in a request for the Latest Fedora Core in the Distro Request Thread and hopefully should be getting a Reply.
Thanks for all your replies guys... Repping you all.
ECE0105 is offline
Old 12-11-2006, 01:11 PM   #11 (permalink)
Best way will be, as Dabster said, to contact your nearest LUG. Check up here List of GNU/Linux user groups in India and on google.
mehulved is offline
