Old 11-11-2006, 12:58 AM   #1 (permalink)
Exclamation problem in compiling kernel
I use knoppix 5.0.1 hd-installed
i try to configure kernek b4 compilation and get the following error
pls help:
HOSTCC scripts/basic/fixdep
In file included from /usr/include/sys/socket.h:35,
from /usr/include/netinet/in.h:24,
from /usr/include/arpa/inet.h:23,
from scripts/basic/fixdep.c:115:
/usr/include/bits/socket.h:304:24: error: asm/socket.h: No such file or directory
make[1]: *** [scripts/basic/fixdep] Error 1
make: *** [scripts_basic] Error 2
ravi.xolve is offline
Old 11-11-2006, 03:45 AM   #2 (permalink)
El mooooo
eddie's Avatar
Default Re: problem in compiling kernel
Do you have kernel-headers/linux-headers (what ever knoppix calls it) installed? You need it to compile anything.
eddie is offline
Old 11-11-2006, 10:50 AM   #3 (permalink)
ya all are in the dir /usr/include
Old 11-11-2006, 09:22 PM   #4 (permalink)
El mooooo
eddie's Avatar
Post the output of following commands
ls -l /usr/include/asm/socket.h
cat /usr/include/linux/version.h
cat /usr/src/linux/include/linux/version.h
ls -l /usr/src/
uname -r
It looks like some kind of symlink problem. Are you using vanilla kernel or some knoppix package?
eddie is offline
