Old 09-11-2006, 11:58 PM   #1 (permalink)
Red face Problem with xfce4 Desktop
Hi all,
Here's the story of my problem :
I am having Xfce4.2.3.2 and Gnome sessions installed in Fedora Core 3 .When i using my xfce session suddenly i am getting Gnome Desktop.
That is with that three icons(Computer,shortcut to home directory and trash) but xfce panel remains .
When i right click it in desktop i'm getting the popup which will appear in Gnome session instead of Xfce popup.When i logout and login i am getting the xfce screens.
what is my problem ?. Please tell me how to solve it .
Thanks
m.parthiban is offline
Old 10-11-2006, 02:32 AM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: Problem with xfce4 Desktop
Thats strange! Why don't u upgrade the distro?? FC6 is out!
mediator is offline
Old 10-11-2006, 03:05 AM   #3 (permalink)
18 Till I Die............
Are you opening any GNOMe application? Specially nautilius.
http://www.bash.org/?258908
mehulved is offline
Old 11-11-2006, 12:28 AM   #4 (permalink)
JGuru's Avatar
@m.parthiban, Open the Terminal Window & give us the output of :
$ ps -ef | grep nautilus
You need to kill those nautilus process.
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
Old 11-11-2006, 03:35 AM   #5 (permalink)
El mooooo
eddie's Avatar
This is why I SOOOOOO HATE nautilus. You start a single instance of this thing and it just wants to take over everything...grrr...
eddie is offline
Old 11-11-2006, 08:14 AM   #6 (permalink)
Orginally posted by : JGuru
Thanks mate , when i type that command i am getting the following output:
500       3401  3382  0 08:19 pts/1    00:00:00 grep nautilus
I don't know what to do next .Can u please explain ?
Old 11-11-2006, 08:34 AM   #7 (permalink)
left this forum longback
praka123's Avatar
dont blame Nautilus for that.i think ur gnome-session is running also same time.
praka123 is offline
Old 11-11-2006, 12:31 PM   #8 (permalink)
JGuru's Avatar
@m.parthiban, You have to kill the Gnome Display Manager(GDM), for that run this command:
$ ps-ef | grep gdm
Your output will look similar to this one.
root      5741     1  0 06:11 ?        00:00:00 /usr/sbin/gdm
root      5742  5741  0 06:11 ?        00:00:00 /usr/sbin/gdm
root      5751  5742  4 06:11 tty7     00:01:48 /usr/bin/X :0 -br -audit 0 -auth /var/lib/gdm/:0.Xauth -nolisten tcp vt7
jguru    7681  6557  0 06:54 pts/1    00:00:00 grep gdm
NOTE: In your case the PID numbers will vary!!
The syntax for killing any Process is 'kill PID' where PID is a number
$ su -
(Enter password)
# kill 5741
# kill 5742
# kill 5751
# exit
This should solve your problem.
-Albert Einstein
JGuru is offline
Old 11-11-2006, 12:57 PM   #9 (permalink)
This means nautilus isn't running. Otherwise you would have got one more process with the name nautilus.
mehulved is offline
Old 11-11-2006, 01:00 PM   #10 (permalink)
String Phreak
mediator's Avatar
^^ Correct nautilus isn't running. Thats the O/P of the grep command!
Neways It might be a bug in FC3.
mediator is offline
Old 11-11-2006, 09:40 PM   #11 (permalink)
praka123's Avatar
Post Re: Problem with xfce4 Desktop
check whether any gnome* runs:
#ps -ax |grep gnome*
praka123 is offline
Old 12-11-2006, 12:39 AM   #12 (permalink)
JGuru's Avatar
@Prakash, The command you have given doesn't produce any output, even though I'm running GNOME!!
But following one works fine.
$ ps -ef | grep gnome*
-Albert Einstein
JGuru is offline
Old 12-11-2006, 01:02 AM   #13 (permalink)
Orginally posted by : JGuru @m.parthiban, You have to kill the Gnome Display Manager(GDM), for that run this command:
$ ps-ef | grep gdm
Yes , i am getting similar output as you have mentioned
Here is the output:
root      4338     1  0 00:59 ?        00:00:00 /usr/bin/gdm-binary -nodaemon
root      4368  4338  0 00:59 ?        00:00:00 /usr/bin/gdm-binary -nodaemon
root      4377  4368  2 00:59 ?        00:00:12 /usr/X11R6/bin/X :0 -audit 0 -auth /var/gdm/:0.Xauth -nolisten tcp vt8
500       4624  4538  0 01:07 pts/1    00:00:00 grep gdm
and i also killed as you said but when i kill any of the the process xfce is restarting immediately .
When i check after restarted again the same processes are running. So what should i do ?
Old 12-11-2006, 01:18 AM   #14 (permalink)
String Phreak
mediator's Avatar
Try to update xfce as root => "yum -y update xfce*"
mediator is offline
Old 12-11-2006, 05:51 AM   #15 (permalink)
praka123's Avatar
i mean,am sorry the correct one 2 try is:
ps  -ax  |grep gnome*
as already ur post is also doing the same.
paarthipan try this and post the o/p.
praka123 is offline
Old 12-11-2006, 12:41 PM   #16 (permalink)
JGuru's Avatar
@m.parthiban, From your output it's very clear that when XFCE session starts, GNOME session(GDM) also starts!!
@Eddie, I think you can shed some light on this one.
-Albert Einstein
JGuru is offline
Old 13-11-2006, 12:15 PM   #17 (permalink)
Output i got:
ps  -ax  |grep gnome*
Warning: bad syntax, perhaps a bogus '-'? See /usr/share/doc/procps-3.2.3/FAQ
 3340 pts/1    S+     0:00 grep gnome*
What u mean ? Sorry, I cannot get you.
Old 13-11-2006, 04:26 PM   #18 (permalink)
praka123's Avatar
@paarthipan:
so no gnome stuffs are running;only gdm in "Xfce DE".so i think you need to purge gdm and dependencies and may be instead use xdm as desktop manager.
praka123 is offline
