Old 09-11-2006, 05:09 PM   #1 (permalink)
saurabh.sauron's Avatar
Default Print, Scan, Copy
i recently got a HP F380 All in one. he problem is that i cant use Xsane to scan images in ubuntu edgy though printing works. In fedora core 5, it doesnt even detect the printer. it is connected in the USB (2.0) port. i am quite sure it is something to do with USB.
pls help
thnx
saurabh.sauron is offline
Old 09-11-2006, 05:46 PM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: Print, Scan, Copy
For fedora issue this as root "yum -y install desktop-printing gimp-print gnome-print hpijs libgnomeprint22 libgnomeprint libgnomeprintui22 libgnomeprintui"
Now enable "cupsd" and "hplip" in service section. Now try installing the printer!
For Xsane : I never tried scanner. Will post when I try it!
mediator is offline
Old 11-11-2006, 03:18 AM   #3 (permalink)
El mooooo
eddie's Avatar
Just install hplip from either hplip.sf.net or it must be in Ubuntu mirrors already. Then launch hp-toolbox and you will be able to perform all actions supported by your printer from there only.
eddie is offline
Old 11-11-2006, 03:41 AM   #4 (permalink)
String Phreak
mediator's Avatar
@saurab : I tried xsane in fedora 5 and it works perfectly! I Will post more about Ubuntu! It seems u don't have the libraries or services enabled!
mediator is offline
