| Forum |
#1 (permalink) |
The following script I am using for inserting the image which is not working. I have changed the buffer and global settings(output_buffering = on and register_globals = on) in php.ini file but with no result. Kindly see the attachment and please help.
Desktop: P-IV 2.4GHz, 512MB DDR, 865GBF Mother Board, G-Force 5200FX, 17" Samsung flat, WinXp with SP2, Kaspersky Internet Security 2009. Laptop:LENOVO 3000 C100 D7 lappy with 2GB DDR2. |
#2 (permalink) |
A bump for all??
#3 (permalink) |
String Phreak
http://hockinson.com/index.php?s=37
But I wud recommend to store them in server folders n use em from there!
Bad Bad server.....No candy for u! |
#4 (permalink) |
I found a good solution with working script(Yes working script) which I want to share with you guys.please see the attachment or click
http://www.dreamwerx.net/phpforum/?id=1 Thanx Mediator, indeed I was also thinking about the same as it is said that unless you are having a good pattern recognition software which can identify a rose from a picture of garden, storing image in database is not a very good idea. Another problem is the size restriction. I want to store a scanned image (in tiff format) which has approximately 35 to 40MB size. This is very very difficult if i use the database.So your solution will be very helpful. can you provide me a script or a link? Thanx in advance.
#5 (permalink) | |
String Phreak
@bukaida : See u can store the image in a folder and develop a php script so that u can manually enter the filepath of that file and make it as a link!
To make an existing file as a link (so that u can open it via link) here's the script! Quote:
U can use this idea to insert the filepath in mysql and retrieve it from there and make it a link !!
#6 (permalink) |
@mediator: Got your idea but can it be used to upload the image file. I mean the image is in client's machine and it should be uploaded to a remote folder at the server so that another client can download and use it.Can you help?
#7 (permalink) |
String Phreak
@bukaida : Sorry dood, I haven't yet tried the remote upload part of php yet! U can manually ftp to upload the file or follow this link! See the php ftp n http section on left hand side!
#8 (permalink) |
In Pursuit of "Happyness"
if ($_FILES['imagefile']['type'] == "image/jpg"){
copy ($_FILES['imagefile']['tmp_name'], "files/".$_FILES['imagefile']['name'])
or die ("Could not copy");
| Bookmarks |
| Thread Tools | |
| Display Modes | |
