| Forum |
#1 (permalink) |
Hey here is the aks
Failed to fetch ftp://cipherfunk.org/pub/packages/ub...er/Release.gpg Could not resolve 'cipherfunk.org' Failed to fetch ftp://cipherfunk.org/pub/packages/ub...86/Packages.gz Could not resolve 'cipherfunk.org' Failed to fetch ftp://cipherfunk.org/pub/packages/ub...rce/Sources.gz Could not resolve 'cipherfunk.org' plz do something ________________ i used both switches -d and -c with gksu as told by jguru
yours truly arun The aks!! have a nice day |
#2 (permalink) |
@Desmataks, This is the correct command to upgrade to Ubuntu Edgy Eft:
$ gksu "update-manager -c" The -d switch is not needed for final release!!
* Imagination is more important than knowledge. -Albert Einstein |
#3 (permalink) |
FooBar Guy
desmataks, you have added some third party repository cypherpunk.org which seems to be down at the moment. Please disable that repo from synaptic and try upgrading/updating again.
JGuru, apt-get dist-upgrade also works like charm.. that's the debian way to do it
- -- http://www.MovieAB.com - A tiny movie mashup! |
#4 (permalink) |
@GNUrag, You are right. apt-get dist-upgrade is the Debian way of doing things. For that command to work, you need to edit the file '/etc/apt/sources.list'
& change the occurence of the word 'dapper' to 'edgy' & save the file. & run the following commands: $ sudo apt-get update $ sudo apt-get dist-upgrade
#5 (permalink) |
Hey here is the aks
when i use this
$ gksu "update-manager -c -d" a new window opens and there is wrtitten a message "upgrade to 6.10 edy ubutu" and a upgrade is button is provided but when i use this $ gksu "update-manager -c" no upgrade info and button is provided so how to upgrade without that button.. i will try apt-get command after replacing dapper word by edgy.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
