Old 28-10-2006, 08:16 PM   #1 (permalink)
antoniobc's Avatar
Exclamation Linux Newbie. Installation Problem
How to install programs that are in the tar.gz compressed format????
antoniobc is offline
Old 28-10-2006, 08:21 PM   #2 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
Default Re: Linux Newbie. Installation Problem
Those are Mostly the Source Files.. i.e. Softwares that are not Compiled Yet..
Search the Stickies for Help...
Edit: This Thread is Extremely Useful.
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 28-10-2006, 08:24 PM   #3 (permalink)
String Phreak
mediator's Avatar
1. Extract the folder in tar to a directory, or files in tar to a folder in a directory!!
2. open terminal and change to that folder
3. command "./configure"
4. command "make" //You shud be able to run files now from that directory by commanding "./executable_file_name"
5. change to root and command "make install" to bring the executables in path!
Some times there are install scripts like "INSTALL.sh", for that command "sh INSTALL.sh". But u shud read the README file first!
mediator is offline
Old 28-10-2006, 09:06 PM   #4 (permalink)
JGuru's Avatar
First extract the compressed file, open the Terminal Window
$ gzip -d package.tar.gz
Now, you'll get a TAR archive file in the same directory.
$ tar xvf package.tar
To install a software package:
$ su -
# ./install.sh
Or you may get a file by name package-install.sh
Also read the file README for full instructions.
To install the package from the Source code:
First you should have installed the C/C++ compilers (gcc, g++, etc.,)
$ ./configure
$ make
$ su -
# make install
You can follow the steps given by @Mediator, I'm just making things more clearer
& simple for you to understand.
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
Old 01-11-2006, 07:19 PM   #5 (permalink)
antoniobc's Avatar
Smile Re: Linux Newbie. Installation Problem
Thanks guys! This stuff some what makes sense. I understood J Guru. I aint a technical person with respect to Linux. Not yet atleast. Anyways thanks you guys!
