Old 28-10-2006, 02:21 PM   #1 (permalink)
String Phreak
mediator's Avatar
Cool Fedora 6 + some features , Check it out!
Source : http://www.redhat.com/magazine/024oc...cm_edmsept_007
Desktop effects
Red Hat has been working on AIGLX through the Fedora Rendering Project, and while we did have it as an optional experimental repository for Fedora Core 5, it has now gone through a number of changes to provide easily enabled desktop effects in your Fedora Core 6 desktop. What have Fedora Core 6 development teams been up to? Here's a few of the things they accomplished:
* Unveiled AIGLX as a community-oriented incremental approach to providing a framework for compositing desktops.
* Merged AIGLX framework into Xorg. It is now available as part of Xorg 7.1 release and will be included in Fedora Core 6.
* Xorg has an improved dynamic configuration mechanism and compositing extension is now enabled by default.
* Changed the OpenGL-based compositing window manager Compiz. It will now work on top of AIGLX and has been tweaked to work better with Fedora.
* Installation of Compiz by default in Fedora Core 6. You can enable it by clicking on the appropriate checkboxes in System=> Preferences => Desktop Effects. With capable hardware it will just work without having to configure anything or even logout of the system.
The results are pretty impressive. While some of these effects are pure eye-candy, others have a more practical value--providing a more physical and tangible feel over application windows and virtual desktops. Not to mention the fresh DNA-themed desktop background
and more check em out!
Looks real cool!
mediator is offline
Old 28-10-2006, 02:34 PM   #2 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
Default Re: Fedora 6 + some features , Check it out!
Ubuntu Edgy + NVIDIA Beta Drivers + Beryl = More Cool Features than Compiz..
Beryl is a Fork of Compiz.. it was called the Compiz-Quinnstorm Before it was Renamed.. Its got Better Features than you know.. and it even Supports full Theming..
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 28-10-2006, 04:18 PM   #3 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
^^ Yup.. Exactly.. Thats got a hell lot more features than FC6 eye candy!
kalpik is offline
Old 28-10-2006, 04:40 PM   #4 (permalink)
String Phreak
mediator's Avatar
Hmmmm........
mediator is offline
Old 28-10-2006, 04:46 PM   #5 (permalink)
JGuru's Avatar
Yeah, Ubuntu rocks for sure. Using Beryl with NVidia Beta drivers you get great effects than Fedora 6!!
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
Old 28-10-2006, 06:46 PM   #6 (permalink)
Downloading FC6
will install tomarrow and make a Triple boot
red_hat is offline
Old 28-10-2006, 06:51 PM   #7 (permalink)
ya....look pretty cool.
jack// ani is offline
Old 01-11-2006, 06:36 AM   #8 (permalink)
I installed fedora Core 6 yesterday.
I installed it in Graphical mode ,it worked perfectly but after finishing installation when pc rebooted and os started loading it shoowed unable to run x server.some modules missing......and went in CLI mode
it has created logfile but how can I paste its output.
I choose nearly all packages except KDE related.
What should I do ?
red_hat is offline
Old 01-11-2006, 10:43 AM   #9 (permalink)
String Phreak
mediator's Avatar
Why dont u chose the full installation mode, and leave no package behind? I alwayz did that n encountered no problem yet!
mediator is offline
Old 04-11-2006, 07:59 AM   #10 (permalink)
what is sys req for fc6?
Old 04-11-2006, 10:02 AM   #11 (permalink)
What is u r sys.config ?
check out here
http://fedoraproject.org/wiki/FAQ#he...743cc017e77d75
red_hat is offline
Old 04-11-2006, 10:34 AM   #12 (permalink)
old p4 2ghz...256mb ram, 64mb graphics...is that suffice??
Old 04-11-2006, 11:07 AM   #13 (permalink)
Yes its more than sufficinet.
red_hat is offline
Old 04-11-2006, 11:08 AM   #14 (permalink)
Commander in Chief
QwertyManiac's Avatar
Dont go for FC6 with that or even FC5 for that matter with a PC a bit old like that. Bloat ups, those are workstation distros. For learning take a debian system, a.k.a Ubuntu. You get ton loads of support and features in those too!
Harsh J
www.harshj.com
QwertyManiac is offline
Old 04-11-2006, 12:16 PM   #15 (permalink)
JGuru's Avatar
@jack// ani, You better upgrade your System to atleast 512 MB RAM. Almost all Linux
distros need atleast 256 MB RAM for decent performance. I think Xubuntu would fit
your PC config perfectly. Also your PC config is not sufficient enough for running Fedora 6.
-Albert Einstein
JGuru is offline
Old 04-11-2006, 04:27 PM   #16 (permalink)
String Phreak
mediator's Avatar
Well I have 2.4 GHz, 512Mb RAM with onboards graphics and FC5 works perfectly on that! So FC6 shud work on u i guess, u may try it!
mediator is offline
Old 04-11-2006, 09:39 PM   #17 (permalink)
left this forum longback
praka123's Avatar
^^ that is far and enough for most distros to work afaik.
praka123 is offline
Old 05-11-2006, 12:56 AM   #18 (permalink)
BSD init pwns System V
hellknight's Avatar
Cool effects, but not much more than SuSE 10.1's XGL, they're gr8 than FC6
hellknight is offline
