Old 27-10-2006, 08:23 PM   #1 (permalink)
saurabh.sauron's Avatar
Default Ubuntu Edgy problems
i am facing problems while installing from the ubuntu disc. i press start or install ubuntu. then it starts the usual loading process and then hangs up. i am not able to install it via synaptic or command line also, are there any other methods to install what can be the cause of my problem. can edgy be installed via command line?
pls help.
thnx
saurabh.sauron is offline
Old 27-10-2006, 08:30 PM   #2 (permalink)
Beneath The Eyelids
The Outsider's Avatar
Default Re: Ubuntu Edgy problems
how bout downloading the alternate install cd?
The Outsider is offline
Old 27-10-2006, 08:35 PM   #3 (permalink)
will it allow me to install it properly? is it command line or is it a safer installation?
Old 27-10-2006, 08:39 PM   #4 (permalink)
Beneath The Eyelids
never did it myself, saw a tutorial though, looks simple + yeah if desktop cd fails thats the recommended solution.
i'm too downloading , only 22% done
Old 27-10-2006, 08:48 PM   #5 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Hmm.. try starting in safe graphics mode. Otherwise as Chester suggested, download the alternate CD, that wont fail!
kalpik is offline
Old 27-10-2006, 09:37 PM   #6 (permalink)
i tried safe graphics mode but that didn't help. now downloading alternate CD. i think that canonical should make it optional to have graphical installation. i prefer the command line that was there in hoary and breezy. i never faced this problem in dapper. maybe coz it is due to my low end rig.
Old 27-10-2006, 11:20 PM   #7 (permalink)
left this forum longback
praka123's Avatar
Post Re: Ubuntu Edgy problems
it is available with ur edgy cd,see the last option while in boot screen,ie,other boot options...try giving the normal debian parameters available or may be already in cd menu.it may have got stuck due to non supported video card.or alternately u can move into other virtual terminal and edit /etc/X11/xorg.conf.
what is your hardware..post it
praka123 is offline
Old 28-10-2006, 12:34 AM   #8 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
pls help.
thnx
wel till dapper , ubuntu live cd didn't work with my DRU 820A , but edgy works fine wven though it drags , i suggest you download the alternate installer cd n install using it .
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 28-10-2006, 10:08 AM   #9 (permalink)
mAYHEM's Avatar
I am also having this problem after the startup screen the screen goes blank with a blinking cursor.
http://www.speedtest.net/result/445135884.png
http://valid.canardpc.com/show_oc.php?id=821188
mAYHEM is offline
Old 28-10-2006, 02:08 PM   #10 (permalink)
i downloaded the alternate edgy cd and everything works perfectly now. from now on, i am going to download the alternative only. i like the text based installation.
also, i cant use users and groups from the administration menu. is it a new feature that denies access to a normal user (even sudoers) to users and groups?
Old 28-10-2006, 03:02 PM   #11 (permalink)
praka123's Avatar
it should work.type "sudo users-admin" it will popup.may be the menu 4 users and grops are not added properly.check by launching "alacarte" menu preferences.
praka123 is offline
Old 29-10-2006, 12:35 AM   #12 (permalink)
JGuru's Avatar
@Saurabh.sauron, You must type the following command:
$ gksu users-admin
It should work now. Try it!!
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
Old 30-10-2006, 11:24 AM   #13 (permalink)
mAYHEM's Avatar
Anyone installed Ubuntu from hard disk.I am able to get the installation started but when it scans the partition for iso files it cant find any.
mAYHEM is offline
