| Forum |
#1 (permalink) | |
The Thread Killer >:)
Thanks in advance.
Want to make this world a better place? Then, start seeding and don't be just a leecher |
#3 (permalink) |
18 Till I Die............
I haven't ever user cool and quiet so don't really know what it is. just attach those drivers in your next post. I will look into it as soon as I get time and reply back.
http://www.bash.org/?258908 |
#4 (permalink) |
El mooooo
FC5 should already be having cpufreq driver compiled as module so you don't need to install it separately from the package you downloaded. Just install cpufreqd from yum or any package manager that you might be using. Then depending on the desktop environment you are using, install relevant package (kcpufreq for KDE) and control the frequency at which you want to run your processor. The more the performance...more heat...less performance...less heat...
#6 (permalink) | |
@tech_your_future Sorry, I can't upload it as the file extension is not valid, 'coz its *.c and *.h extensions. Waiting for more advice on this, if any. Thanks again!!
#7 (permalink) | |
"The Cake is a Lie!!"
![]() (Well, Compiling them ain't tough.. But you will need a Lot of Know-How.. and As Posted above, Cool & Quiet Drivers are Inbuilt in the Linux Kernel)
[xubz] ● http://xubz.com/ [steam_id] ● http://steamcommunity.com/id/xubz |
#8 (permalink) | |
Beneath The Eyelids
#9 (permalink) | |
Thanks in advance.
#10 (permalink) | |
El mooooo
mkdir /mnt/suse mount /dev/hda6 /mnt/suse chroot /mnt/suse /bin/bash passwd |
#11 (permalink) |
Thanks!! The install is fine, but with few issues, but starting a new thread so that everyone can make use of it.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
