| Forum |
#2 (permalink) |
ubuntu is not made for dial up! u can not connect dialup on ubuntu for more than 1-2 minute that is coz of bug in ubuntu.( source ubuntu irc, ubuntu forum)so try any other distro any but except ubuntu.
here is the tutorial http://www.desi-tek.com/forum/index....iew=getnewpost have fun Last edited by Desi-Tek.com; 21-10-2006 at 01:20 PM. |
#3 (permalink) | |
Beneath The Eyelids
@DR RANJAN connect your phone properly, open terminal, type Code:
sudo wvdialconf Last edited by The Outsider; 21-10-2006 at 01:29 PM. |
#4 (permalink) |
than u r lucky mate
#5 (permalink) |
18 Till I Die............
In Dapper?
Maybe it's specific to some kind of hardware that you're using. Can you be more specific on that bug. It may help somebody else.
http://www.bash.org/?258908 |
#7 (permalink) |
here it is http://ubuntuforums.org/showthread.php?t=269876
and here is reported bug https://launchpad.net/bugs/40855 i am not the only 1 but lots of user r facing this problem and only on ubuntu. But wvdial works very smoothly on fedora4 and other distro. Last edited by Desi-Tek.com; 21-10-2006 at 05:48 PM. Reason: .. |
#8 (permalink) |
Beneath The Eyelids
that sounds allright mate but i know people from this forum who have dialup workin fine on ubuntu/xubuntu/kubuntu dapper, for eg: led_shankar.
the line dropping problem happened to me too, but it was solved as i left wvdial & connected through the gui interface i.e. the "networking" tool found in applications (assuming i have gnome) & ofcourse i have a smartlink softmodem/winmodem. |
#9 (permalink) | |
even i also tried that but it didn't worked for me
thats why i am now using fedora 4. Quote:
#10 (permalink) |
@Desi-Tek, The problem is that Ubuntu doesn't work very well with all hardware.
Dial-up works very well for me. So you shouldn't come to a conclusion that Ubuntu doesn't support dial-up!! Yes, there are some bugs. Let's hope in future releases of Ubuntu things are sorted out.
* Imagination is more important than knowledge. -Albert Einstein |
#11 (permalink) |
but it is able to detect my mobile, prolific chipset datacable. and i am able to connect gprs on ubuntu but it remains active only for 1-2minute than it get disconnected. so how can i say that it does not support my mobile or datacable or hardware?
#12 (permalink) |
left this forum longback
ur h/w are all detected yaar.u can verify it using "lspci" command its listing.they detected this as a bug too.then after this much time no fix?...
i tried dialup last on ubuntu hoary only and it worked perfectly.also not on a moby phone .but using a ISP+external dialup56kbps modem. so i configure /etc/wvdial.conf using wvdialconf command and then set the connxn using pppconfig command and dialled either "wvdial" or "pon ppp0" for connxn had u tried this method?
left this forum long back.Admin Can Delete this Account and posts Permanantly.Thank You Get GNU/Linux - http://getgnulinux.org |
#13 (permalink) | |
may be thats why author of that thread on launchpad made this comment
i think instead of wasting time in creating new distro linux developer should concentrate in providing quality. |
#14 (permalink) |
hi chester, i use ur trick, but its not work for me!!!
__________ hi desi_tek, i want ur suggestion about linux. plz tell me...which one(linux os) support dialup connection & easy to easy to use for beginners Last edited by DR RANJAN; 29-10-2006 at 11:24 AM. Reason: Automerged Doublepost |
#15 (permalink) | |
Beneath The Eyelids
don't worry i have the same phone and data cable. |
#16 (permalink) |
finally i switched to fedora now i have no problem in connecting gprs and every thing is running fine for me
@DR RANJAN go for any distro other than ubuntu and family. u will be able to connect gprs. ubuntu has some serious problem with kppp
Dhiraj Thakur thakur.dheeraj(@)gmail.com |
#17 (permalink) |
Beneath The Eyelids
still don't fully agree to you mate, yesterday i installed Kubuntu dapper on my friends pc and yes getin dialup to work was pain,
kppp couldn't find /etc/resolv.conf the ppp daemon died unexpectedly etc etc same happened with wvdial, at last i was able to connect by appending "Carrier Check = NO" in /etc/wvdial.conf have to agree kppp sucks Last edited by The Outsider; 29-10-2006 at 04:22 PM. |
#18 (permalink) |
but it works fine on fedora. and ubuntu has problem with SLIP/PPP (Point-to-Point Protocol ). and i used almost all the dialer available on Ubuntu but none of them worked for me. it only allow me to access net for 1-2 minute than it gives up.
and i am facing this problem only with gprs. never tested with external dialup modem. and this is the output of wvdialconf Code:
[root@localhost Dheeraj]# wvdialconf /etc/wvdial.conf Scanning your serial ports for a modem. ttyS0<*1>: ATQ0 V1 E1 -- failed with 2400 baud, next try: 9600 baud ttyS0<*1>: ATQ0 V1 E1 -- failed with 9600 baud, next try: 115200 baud ttyS0<*1>: ATQ0 V1 E1 -- and failed too at 115200, giving up. Port Scan<*1>: S1 S2 S3 S4 S5 S6 S7 S8 Port Scan<*1>: S9 S10 S11 S12 S13 S14 S15 S16 Port Scan<*1>: S17 S18 S19 S20 S21 S22 S23 S24 Port Scan<*1>: S25 S26 S27 S28 S29 S30 S31 S32 Port Scan<*1>: S33 S34 S35 S36 S37 S38 S39 S40 Port Scan<*1>: S41 S42 S43 S44 S45 S46 S47 S48 Port Scan<*1>: S49 S50 S51 S52 S53 S54 S55 S56 Port Scan<*1>: S57 S58 S59 S60 S61 S62 S63 S64 Port Scan<*1>: S65 S66 S67 S68 S69 S70 S71 S72 Port Scan<*1>: S73 S74 S75 ttyUSB1<*1>: ATQ0 V1 E1 -- failed with 2400 baud, next try: 9600 baud ttyUSB1<*1>: ATQ0 V1 E1 -- failed with 9600 baud, next try: 115200 baud ttyUSB1<*1>: ATQ0 V1 E1 -- OK ttyUSB1<*1>: ATQ0 V1 E1 Z -- OK ttyUSB1<*1>: ATQ0 V1 E1 S0=0 -- OK ttyUSB1<*1>: ATQ0 V1 E1 S0=0 &C1 -- OK ttyUSB1<*1>: ATQ0 V1 E1 S0=0 &C1 &D2 -- OK ttyUSB1<*1>: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0 -- OK ttyUSB1<*1>: Modem Identifier: ATI -- LG Electronics Inc. ttyUSB1<*1>: Speed 230400: AT -- ttyUSB1<*1>: Speed 230400: AT -- ttyUSB1<*1>: Speed 230400: AT -- \uffff\uffff ttyUSB1<*1>: Max speed is 115200; that should be safe. ttyUSB1<*1>: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0 -- OK Found a modem on /dev/ttyUSB1. Modem configuration written to /etc/wvdial.conf. ttyUSB1<Info>: Speed 115200; init "ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0" Ill be ver very thankfull if u will solve this problem Code:
root@avtar:/home/dheeraj# wvdial --> WvDial: Internet dialer version 1.55 --> Cannot get information for serial port. --> Initializing modem. --> Sending: ATZ ATZ OK --> Sending: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0 ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0 OK --> Sending: AT+CGDCONT=1,"IP","airtelgprs.com"; AT+CGDCONT=1,"IP","airtelgprs.com"; OK --> Modem initialized. --> Sending: ATDT*99***2# --> Waiting for carrier. ATDT*99***2# CONNECT ~[7f]}#@!}!}8} }<}!}$}&@}#}$@#}%}&_8^G}"}&} } } } }'}"}(}"[1a]e~~~ --> Carrier detected. Starting PPP immediately. --> Starting pppd at Sat Oct 28 07:10:25 2006 --> Pid of pppd: 8791 --> Using interface ppp0 --> pppd: ��[05][08]�[01][06][08] --> pppd: ��[05][08]�[01][06][08] --> pppd: ��[05][08]�[01][06][08] --> pppd: ��[05][08]�[01][06][08] --> pppd: ��[05][08]�[01][06][08] --> pppd: ��[05][08]�[01][06][08] --> local IP address 10.190.202.94 --> pppd: ��[05][08]�[01][06][08] --> remote IP address 10.0.0.1 --> pppd: ��[05][08]�[01][06][08] --> primary DNS address 202.56.230.5 --> pppd: ��[05][08]�[01][06][08] --> secondary DNS address 202.56.240.5 --> pppd: ��[05][08]�[01][06][08] --> pppd: ��[05][08]�[01][06][08] --> pppd: ��[05][08]�[01][06][08] --> pppd: ��[05][08]�[01][06][08] --> pppd: ��[05][08]�[01][06][08] --> pppd: ��[05][08]�[01][06][08] --> Connect time 2.0 minutes. --> pppd: ��[05][08]�[01][06][08] --> pppd: ��[05][08]�[01][06][08] --> pppd: ��[05][08]�[01][06][08] --> Disconnecting at Sat Oct 28 07:12:28 2006 --> The PPP daemon has died: Lack of LCP echo responses (exit code = 15) --> man pppd explains pppd error codes in more detail. --> I guess that's it for now, exiting --> Provider is overloaded(often the case) or line problem. --> The PPP daemon has died. (exit code = 15)
Dhiraj Thakur thakur.dheeraj(@)gmail.com Last edited by Desi-Tek.com; 30-10-2006 at 07:22 AM. Reason: Automerged Doublepost |
#19 (permalink) |
El mooooo
@Desi-Tek.com: Check the contents of your /etc/ppp/options file. If you have anything like lcp-echo-failure mentioned in the file then delete that line and any others related to lcp. If you don't know how to edit the file manually then post the contents here and one of us will tell you how to do it correctly or else you might create more problems for yourself.
As for your NTFS problem. You don't need a new version of distro...you need a new kernel. Just download the kernel source from www.kernel.org and compile one yourself. |
#20 (permalink) | |
ab
its complete credit goes to u. it is difficult for me to believe but thats true now i can access non stop net on ubuntu can u pls tell me wat does lcp realy means? and why it was not allowing me to connect gprs for more than 2 minute? gprs?
Dhiraj Thakur thakur.dheeraj(@)gmail.com Last edited by Desi-Tek.com; 16-11-2006 at 08:45 PM. |
#21 (permalink) |
@Desi_Tek, LCP means Link Control Protocol. Reason :
lcp-echo-failure n If this option is given, 'pppd' will presume the peer to be dead if n LCP echo-requests are sent without receiving a valid LCP echo-reply. If this happens, 'pppd' will terminate the connection. Use of this option requires a non-zero value for the lcp-echo- interval parameter. This option can be used to enable pppd to terminate after the physical connection has been broken (e.g., the modem has hung up) in situations where no hardware modem control lines are available.
#22 (permalink) |
You'r Born Free
I cant edit the wvdial file in etc folder.
I neither can delete or paste in that folder. But I can run the sudo command succesfully in the terminal with the same login id and pass
# Money, Beauty and Configration has no ends. # Life is like game sometimes. Play it or loose it. But keep the spirit of game. http://en.wikipedia.org/wiki/Right_to_Information_Act |
#24 (permalink) |
Wandering in time...
Hey didn't want to start a new thread so asking my query realated to net in ubuntu here itself...
After a bit of struggle i managed to get my MTNL TriBand net connection running on Ubuntu Dapper... That i managed when my mode in router was pppoe... But i prefer using the bridge mode... So how do i make a pppoe connection in ubuntu to connect my net using it... Is it possible and do i have to download any packages for it...
Integrate Yourself With The Latest Happenings..... www.ankur-gupta.com/blog |
#25 (permalink) | ||
GaurishSharma.com
see if RP-PPPoEworks for u however it did'nt work for me __________ Quote:
http://ubuntuguide.org/wiki/Ubuntu_E...er_in_Nautilus hey just go through the ubuntu guide page it more than enough for a newbie before u ask an query Last edited by gary4gar; 07-03-2007 at 10:07 AM. Reason: Automerged Doublepost |
#26 (permalink) |
You'r Born Free
Thanx all
resolved
#27 (permalink) | |
El mooooo
#28 (permalink) |
Yeah tried using pppoeconf command but it gives error message that some controller not found or something like that...
#30 (permalink) |
El mooooo
It would be great if you people actually gave the error messages instead of posting "some controller not found". If you post in such a way then only advice you'll get is to install "some controller" which you can grab from "some place" at "some price".
| Bookmarks |
| Thread Tools | |
| Display Modes | |
