03-10-2006, 04:38 PM
Packages installation
Hi techies
I want some help fr u guys.
I installed RHEL 4 OS.So i havent any issue with installation of os.
I want to configure internet so that I dont have to swich again and agin to xp for net.
I have sify broadband and have a sifyconnect-1.3-bin.tar.gz package fr there site.I dont know how to install that.  I configured DHCP by inputting ip ,gateway,dns provided by sify so am on lan.
I also want to install Bit torrent client i.e .Azureus ,JAva for that ,MP3 Player ,VLC player and any download manager like flashget in windows for download fr RS or any other file hosting site.Which package should I download fr Sourceforge.net
Thanks in advance.
03-10-2006, 04:59 PM
18 Till I Die............
Re: Packages installation
Maybe someone with sify connection will tell you how to connect. But, you can attach that file over here, it will have instructions on how to install it.
Just untar and unzip it using
su
cd <to wherever your file is stored>
tar xzvf sifyconnect-1.3-bin.tar.gz
Now read the instruction in the directory and follow them.
__________
For installing those just download yum and follow Stanton Finley Notes. For more info on that search the forum or on google.
http://www.bash.org/?258908
Reason: Automerged Doublepost
03-10-2006, 05:11 PM
@Red_hat, if you have enabled 'DHCP' then you should be able to connect to the Net!!
There's no need for providing your ISP's IP address, Gateway etc., 'DHCP' will configure
it automatically.
Azureus , download it from here
You need to install Java JRE, download Java Runtime Environment (JRE) 5.0 Update 9 from here
VLC Media player Download from here
XMMS MP3 player Download from here
D4X (Download Manager like FlashGet) Download it from here
@Mehul, The correct commands for unzipping a 'tar.gz' file is as follows:
$ gzip -d sifyconnect-1.3-bin.tar.gz
This will extract the TAR archive in the same directory
Now extract the TAR archive. ( sifyconnect-1.3-bin.tar)
$ tar xvf sifyconnect-1.3-bin .tar
You'll get a executable binary
$ ./install.sh (or something similar)
* Imagination is more important than knowledge.
-Albert Einstein
03-10-2006, 06:45 PM
left this forum longback
perhaps
http://atrpms.net
is the best bet for fedora rpms....
03-10-2006, 09:31 PM
Why go to all those sites when you can do it easily from yum or smart, I prefer latter.
[b]$ gzip -d sifyconnect-1.3-bin.tar.gz
Well there are multiple methods. One that I gave works fine, even the one you have given. Another one that I know of is
gzip -dc sifyconnect-1.3-bin .tar | tar xvf
Which is nothing but your command concanated into one line instead of two. I prefer to do less work  .
I prefer the method which I gave first, it makes no difference whichever method you use.
04-10-2006, 01:29 AM
sify will not work in Linux
04-10-2006, 07:27 AM
In Pursuit of "Happyness"
Umm.. I had sify once, and their linux client worked.. Either way, even their MAC client will work cuz its java based.
04-10-2006, 10:28 PM
I extracted and changed destination to that file and then gave command
as u guys told ./install
and sify client installed sucssesfully but while logging in it showed
plz download latest client ,whereas i downloaded latest client .
Here is a screenshot
How to configure that , is it by default or i have to download and install them ?
I am downloadin all these softs now and will install and ask if any prob. arise
btw thnx for u r help techies.
04-10-2006, 10:46 PM
Me too facing the same problem and has contacted CC 2 times within 4 days. But still waiting for a reply
04-10-2006, 10:54 PM
You can download yum from the net just search on google. And read Stanton Finley Notes, google will point you to it.
05-10-2006, 05:03 PM
Today I contacted CC and my problem is solved.
Hurray My net is working fine ,now i dont have to switch again and agin.
I can also make practise on this platform.
I installed real Player.
Tried xmms player but it showed error of GLIB 1.2.2 missing.
for Azureus it showed java not found whereas i installed jdk-1_5_0_09-nb-5_0-linux-ml.bin by rite clickin and choosin option run in terminal that started GUI installation
so rest of the softs am downloading now so i will reply at nite
05-10-2006, 05:37 PM
Real player is c**p. There are a lot better media players like mplayer, VLC, Amarok, XMMS, Xine.
That is why I am suggesting you yum. It will handle dependancies and make your life lot easier.
06-10-2006, 12:59 AM
I downloaded these 2 packages
yum-3.0.tar.gz & yum-3.0-1.src.rpm
extracted tar file and gave make command its output is -:
[root@blackpearl yum-3.0]# make
for d in rpmUtils yum etc docs; do make PYTHON=python -C $d; [ $? = 0 ] || exit 1 ; done
make[1]: Entering directory `/root/Desktop/yum-3.0/rpmUtils'
echo "Nothing to do"
Nothing to do
make[1]: Leaving directory `/root/Desktop/yum-3.0/rpmUtils'
make[1]: Entering directory `/root/Desktop/yum-3.0/yum'
Nothing to do
make[1]: Leaving directory `/root/Desktop/yum-3.0/yum'
make[1]: Entering directory `/root/Desktop/yum-3.0/etc'
Nothing to do
make[1]: Leaving directory `/root/Desktop/yum-3.0/etc'
make[1]: Entering directory `/root/Desktop/yum-3.0/docs'
Nothing to do
make[1]: Leaving directory `/root/Desktop/yum-3.0/docs'
[root@blackpearl yum-3.0]# make install
mkdir -p /usr/share/yum-cli
for p in callback.py cli.py i18n.py output.py progress_meter.py shell.py translate.py yumcommands.py yummain.py yum-updatesd.py ; do \
install -m 644 $p /usr/share/yum-cli/$p; \
done
mv /usr/share/yum-cli/yum-updatesd.py /usr/share/yum-cli/yumupd.py
python -c "import compileall; compileall.compile_dir('/usr/share/yum-cli', 1, '', 1)"
Listing /usr/share/yum-cli ...
Compiling /usr/share/yum-cli/callback.py ...
Compiling /usr/share/yum-cli/cli.py ...
Compiling /usr/share/yum-cli/i18n.py ...
Compiling /usr/share/yum-cli/output.py ...
Compiling /usr/share/yum-cli/progress_meter.py ...
Compiling /usr/share/yum-cli/shell.py ...
Compiling /usr/share/yum-cli/translate.py ...
translate.py:117: FutureWarning: hex/oct constants > sys.maxint will return positive values in Python 2.4 and up
if _StrToInt(buffer[:4]) != 0x950412de:
translate.py:162: FutureWarning: hex/oct constants > sys.maxint will return positive values in Python 2.4 and up
f.write(_intToStr(0x950412de)) # magic number
Compiling /usr/share/yum-cli/yumcommands.py ...
Compiling /usr/share/yum-cli/yummain.py ...
Compiling /usr/share/yum-cli/yumupd.py ...
File "yumupd.py", line 200
@dbus.service.signal('edu.duke.linux.yum')
SyntaxError: invalid syntax
mkdir -p /usr/bin /usr/sbin
install -m 755 bin/yum.py /usr/bin/yum
install -m 755 bin/yum-updatesd.py /usr/sbin/yum-updatesd
mkdir -p /var/cache/yum
for d in rpmUtils yum etc docs; do make PYTHON=python DESTDIR=`cd ; pwd` -C $d install; [ $? = 0 ] || exit 1; done
mkdir -p /root//usr/lib/python2.3/site-packages/rpmUtils
for p in arch.py __init__.py miscutils.py oldUtils.py transaction.py updates.py ; do \
install -m 644 $p /root//usr/lib/python2.3/site-packages/rpmUtils/$p; \
done
python -c "import compileall; compileall.compile_dir('/root//usr/lib/python2.3/site-packages/rpmUtils', 1, '', 1)"
Listing /root//usr/lib/python2.3/site-packages/rpmUtils ...
Compiling /root//usr/lib/python2.3/site-packages/rpmUtils/__init__.py ...
Compiling /root//usr/lib/python2.3/site-packages/rpmUtils/arch.py ...
Compiling /root//usr/lib/python2.3/site-packages/rpmUtils/miscutils.py ...
Compiling /root//usr/lib/python2.3/site-packages/rpmUtils/oldUtils.py ...
Compiling /root//usr/lib/python2.3/site-packages/rpmUtils/transaction.py ...
Compiling /root//usr/lib/python2.3/site-packages/rpmUtils/updates.py ...
mkdir -p /root//usr/lib/python2.3/site-packages/yum
for p in comps.py config.py constants.py depsolve.py Errors.py failover.py __init__.py logginglevels.py mdparser.py misc.py packageSack.py packages.py parser.py pgpmsg.py plugins.py repoMDObject.py repos.py rpmsack.py sqlitecache.py sqlitesack.py storagefactory.py transactioninfo.py update_md.py yumRepo.py ; do \
install -m 644 $p /root//usr/lib/python2.3/site-packages/yum/$p; \
done
python -c "import compileall; compileall.compile_dir('/root//usr/lib/python2.3/site-packages/yum', 1, '', 1)"
Listing /root//usr/lib/python2.3/site-packages/yum ...
Compiling /root//usr/lib/python2.3/site-packages/yum/Errors.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/__init__.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/comps.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/config.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/constants.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/depsolve.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/failover.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/logginglevels.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/mdparser.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/misc.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/packageSack.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/packages.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/parser.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/pgpmsg.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/plugins.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/repoMDObject.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/repos.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/rpmsack.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/sqlitecache.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/sqlitesack.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/storagefactory.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/transactioninfo.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/update_md.py ...
Compiling /root//usr/lib/python2.3/site-packages/yum/yumRepo.py ...
mkdir -p /root/etc/yum.repos.d
install -m 644 yum.conf /root/etc/yum.conf
mkdir -p /root/etc/logrotate.d
install -m 644 yum.logrotate /root/etc/logrotate.d/yum
mkdir -p /root/etc/rc.d/init.d
install -m 755 yum-updatesd.init /root/etc/rc.d/init.d/yum-updatesd
mkdir -p /root/etc/dbus-1/system.d/
install -m 755 yum-updatesd-dbus.conf /root/etc/dbus-1/system.d/yum-updatesd.conf
mkdir -p /root/etc/yum/
install -m 755 yum-updatesd.conf /root/etc/yum/yum-updatesd.conf
mkdir -p /root/usr/share/man/man{5,8}
install -m 644 yum.8 /root/usr/share/man/man8/yum.8
install -m 644 yum-shell.8 /root/usr/share/man/man8/yum-shell.8
install -m 644 yum.conf.5 /root/usr/share/man/man5/yum.conf.5
install -m 644 yum-updatesd.8 /root/usr/share/man/man8/yum-updatesd.8
install -m 644 yum-updatesd.conf.5 /root/usr/share/man/man5/yum-updatesd.conf.5
and when tried to install rpm
[root@blackpearl Desktop]# rpm -ivh yum-3.0-1.src.rpm
warning: yum-3.0-1.src.rpm: V3 DSA signature: NOKEY, key ID 69886cc7
1:yum warning: user skvidal does not exist - using root
warning: group skvidal does not exist - using root
warning: user skvidal does not exist - using root)
########################################### [100%]
Whatever i did is rite or how to do if it improper ?
__________
I also referred Stanton Finley notes
when i gave
# yum -y update
its output is
There was a problem importing one of the Python modules
required to run yum. The error leading to this problem was:
No module named yum
Please install a package which provides this module, or
verify that the module is installed correctly.
It's possible that the above module doesn't match the
current version of Python, which is:
2.3.4 (#1, Feb 2 2005, 11:44:49)
[GCC 3.4.3 20041212 (Red Hat 3.4.3-9.EL4)]
06-10-2006, 02:22 AM
Hi techies
I want some help fr u guys.  I installed RHEL 4 OS.So i havent any issue with installation of os.
for rhel4 yum goto http://atrpms.net/dist/el4/yum/
download ur architecture(x86?) and install using rpm -ivh xxx.rpm or jus by double-cliking,stop trying compiling from sources stuff,rpm or deb are those equivalent to installshield thing(that next,next thing for setup in ur windows xp).compiling from sources is OK,But...for n00b's i believe trying rpms is way better.
just read as t_y_f said stanton finley's fedora install note;fedora is the successor from redhat9 onwards while RHEL4...is a paid subscription for updates,security fixes which enterprises customers and few training walla's use.
i assume u a n00b?
so i recommend u use Debian or Ubuntu or may be Fedora 6.
Also Linux is a free software as Niyam Bhushan in LFY said Muft and Mukth
free as in freedom, not free lunch. In Hindi "mukth" means freedom and
"mufth" means free of cost, or Free as in "swathanthra" not "soujanya"
06-10-2006, 09:18 AM
@Prakash Kerala thnx for site recommended by u and for advice regarding distro.
but i want to settle on rhel then i will like to try other distros like ubuntu ,centos ,etc
I downloaded RPMs fr http://atrpms.net
Tried to install yum
# rpm -ivh yum-2.9.4-74.el4.at.x86_64.rpm
warning: yum-2.9.4-74.el4.at.x86_64.rpm: V3 DSA signature: NOKEY, key ID 66534c2b
error: Failed dependencies:
/usr/lib/python2.3/site-packages/elementtree is needed by yum-2.9.4-74.el4.at.x86_64
/usr/lib/python2.3/site-packages/urlgrabber is needed by yum-2.9.4-74.el4.at.x86_64
/usr/lib64/python2.3/site-packages/rpm is needed by yum-2.9.4-74.el4.at.x86_64
/usr/lib64/python2.3/site-packages/sqlite is needed by yum-2.9.4-74.el4.at.x86_64
/usr/lib64/python2.3/site-packages/sqlitecachec.py is needed by yum-2.9.4-74.el4.at.x86_64
so i installed pythonabi-2.3-3.el4.at.x86_64.rpm package sucssesfully and again tried to install yum package but same error as above displayed.
Wha should i do?
Why am unable to install an package?
Btw thnx again to all of u for u r help and guidance.
06-10-2006, 09:25 AM
Dependancies are missing that is why you are unable to install these packages. I am not too familiar with RHEL but you should have some way of installing packages from CD/DVD and yum should be present in there, it may install yum with it's dependancies.
Or else you will need elementtree, urlgrabber, rpm, sqlite, sqlitecachec.py and maybe their dependancies.
But, why use RHEL? It's meant for servers, if you still prefer Red Hat then go for Fedora, which is a community project.
06-10-2006, 10:32 AM
perhaps u may install devel libraries for eg: python-dev etc using ur rhel command as root:
system-config-packages
packagesmay be listed there.try finding the dependencies like python2.3-dev,rpm-dev,etc and install
06-10-2006, 02:06 PM
ok i thought since RHEL is Enterprise version it will be better than Fedora
So I chose RHEL.
I selected all packages for installation except kde related from Add/Remove
Applications still facing prob. and not able to install yum.
I downloaded nearly all softs from http://atrpms.net/dist/el4/yum/ starting from lib and python but many of them faced same dependencies error.
btw How to install source rpm and jdk-1_5_0_09-linux-i586-rpm.bin
07-10-2006, 05:13 AM
#19 (permalink)
dont u have yum in the options add/remove menu?
building source rpms?
http://mia.ece.uic.edu/~papers/linux/msg00021.html
4. ONE STEP BUILD PROCEDURE.
A. You can usually build the binary RPM in one step. The following command
will "install" the sources, create a binary RPM, and clean up the rpm
subdirectories when it's done (Note 1):
rpm --rebuild foo-1.0.0-1.src.rpm &> rebuild.log
Examine rebuild.log to be sure that the build completed successfully.
B. Install the binary .rpm package, updating the rpm database. The binary
RPM you just created is located in the RPMS directory tree:
cd ~/rpm/RPMS/i386 (for 386 architecture)
su
rpm -Uvh foo-1.0.0-1.i386.rpm
exit
installing java other plugins...bud refer below link of stanton finley..
http://www.stanton-finley.net/fedora...ion_notes.html
08-10-2006, 11:11 PM
#20 (permalink)
@ thnx Prakash Kerla .Got how to install sorce rpm.
But now I replaced RHEL with CentOS.
It has inbuilt yum installed.
So I am following stanton-finley notes and came upto yum update
which is updating system and takin long time..................but no problem.
i am also referring documentation from their site regarding how to use yum etc.
If I faced any problem then I will disturb u guys again.
Thnx to everyone for spending u r valuable time.
__________
Hi buddies
I am agin frustrated with this installation .
I updated my os with yum update.
now i am tryin to install some softs using yum
but facin some pronb.
[root@tuxian Desktop]# yum install azureus
Setting up Install Process
Setting up repositories
Reading repository metadata in from local files
Parsing package install arguments
No Match for argument: azureus
Nothing to do
[root@tuxian Desktop]# yum -y install mplayer mplayer-skins mplayer-fonts
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Package mplayer-fonts.noarch 0:1.1-3.fc set to be updated
---> Package mplayer.i386 0:1.0-0.20.pre7.2.fc4 set to be updated
---> Downloading header for mplayer-skins to pack into transaction set.
mplayer-skins-1.7-1.fc.no 100% |=========================| 217 kB 00:14
---> Package mplayer-skins.noarch 0:1.7-1.fc set to be updated
--> Running transaction check
--> Processing Dependency: libaa.so.1 for package: mplayer
--> Processing Dependency: liblzo.so.1 for package: mplayer
--> Processing Dependency: libmp3lame.so.0 for package: mplayer
--> Processing Dependency: libfribidi.so.0 for package: mplayer
--> Processing Dependency: liblirc_client.so.0 for package: mplayer
--> Processing Dependency: libdvdread.so.3 for package: mplayer
--> Processing Dependency: libxvidcore.so.4 for package: mplayer
--> Processing Dependency: libXvMCW.so.1 for package: mplayer
--> Processing Dependency: libmad.so.0 for package: mplayer
--> Restarting Dependency Resolution with new changes.
---> Package xvidcore.i386 0:1.0.3-1.2.fc4 set to be updated
---> Package fribidi.i386 0:0.10.4-6 set to be updated
---> Package lame.i386 0:3.96.1-2.2.fc4 set to be updated
---> Package libXvMCW.i386 0:0.9.3-1.2.fc4 set to be updated
---> Package libdvdread.i386 0:0.9.4-8cvs.2.fc4 set to be updated
---> Package libmad.i386 0:0.15.1b-3.2.fc4 set to be updated
--> Processing Dependency: libdvdcss >= 1.2.5 for package: libdvdread
---> Package libdvdcss.i386 0:1.2.9-1.2.fc4 set to be updated
--> Finished Dependency Resolution
Error: Missing Dependency: libaa.so.1 is needed by package mplayer
Error: Missing Dependency: liblzo.so.1 is needed by package mplayer
Error: Missing Dependency: liblirc_client.so.0 is needed by package mplayer
same with vlc ,xine, etc.
yum handles dependancies ,so why still same problem ?
08-10-2006, 11:58 PM
#21 (permalink)
So I chose RHEL.
See you have no clue on how the Open Source model works. Well nither did I know when I started  and even now I can't claim to know it perfectly.
But, in the Open Source arena. It's rather community projects which are usually better. Some reasons are listed below
1) It is used extensively by the community so it is well tested
2)It has lots of developers who happen to be the users of the software too, so it's some issues which aren't well tackled in enterprise systems so well are addressed in the community distro.
3) RHEL, SLED,etc are optimised for server usage. This doesn't mean it's bad for desktop or anything as such but it will be some steps beyond FC or OpenSUSE cos most geeks in the community will be using FC, SUSE, Ubuntu,etc so the documents you will get hold of on the net for the latter will be far better.
There are more points but I can't remember some and am feeling lazy to write down more, too. So, using RHEL or it's clone CentOS will not give you any advantage whatsoever over FC, unless you pay for RHEL and get tech support from RH.
I am not so familiar with yum so can't help you about the yum problem now, but I will look it up if I get time soon and it has not been answered.
09-10-2006, 12:12 AM
#22 (permalink)
@Red_hat, RHEL is used by very large companies since they need such a O.S that
supports clustering, scalability, mutiple Processor support, data recovery etc.,
It's mainly for the Enterprise. I suggest you switch to Fedora Core 5. We can help
solve your problems easily. Fedora is a good distro.Also it's easy to learn things.
-Albert Einstein
09-10-2006, 12:49 AM
#23 (permalink)
@ Tech u r future ,J guru
: I was totally unaware about the things which u explained so I will consdier u r points.
I will install either ubuntu or FC5 .
I have to download these disros so will take little bit time.
Thnx for help.
09-10-2006, 01:54 PM
#24 (permalink)
OK it seems all your yum channels weren't updated. Just do
yum clean all
yum -y update
See this http://www.openfree.org/forums/showthread.php?t=15610
10-10-2006, 12:37 PM
#25 (permalink)
Error: Missing Dependency: libraw1394.so.8 is needed by package libavc1394
this was the last line after following above procedure..
btw am going to install ubuntu 6.06 today.
10-10-2006, 05:43 PM
#26 (permalink)
@red_hat get the needed libraw1394 rpm from :
http://atrpms.net/dist/el4/libraw1394/
11-10-2006, 08:08 PM
#27 (permalink)
Originally Posted by prakash kerala
OOps I installed Ubuntu .
We have to use sudo .Isnt there any method or default pwd to become a root user?
11-10-2006, 08:54 PM
#28 (permalink)
@Red_hat, You don't need root password at all in Debian-based Linux distros like Ubuntu.
Use sudo, gksudo, gksu followed by a command,
For eg., to open a file & write to it, of which the 'root' has read, write, execute permission.
Open the Terminal Window & type;
$ sudo gedit /etc/X11/xorg.conf
This is just an example.
Now make changes to the file & save it. That's all.
The syntax is 'sudo command' The command is any command that requires root priviledges.
To display your harddisk partition, type:
$ sudo fdisk -l
The output you get will be some what like this:
Disk /dev/hda: 40.0 GB, 40060403712 bytes
255 heads, 63 sectors/track, 4870 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/hda1 * 1 638 5124703+ b W95 FAT32
/dev/hda2 639 3982 26860680 f W95 Ext'd (LBA)
/dev/hda5 639 1403 6144831 b W95 FAT32
/dev/hda6 1404 2041 5124703+ b W95 FAT32
/dev/hda7 2042 2770 5855661 83 Linux
/dev/hda8 2807 3827 8201151 b W95 FAT32
/dev/hda9 3828 3982 1244974+ 82 Linux swap / Solaris
NOTE: In your case the output may vary!!
-Albert Einstein
11-10-2006, 10:15 PM
#29 (permalink)
Don't use root. It is an unnecessary security risk. sudo lets you do everything that needs to be done by a root user.
It is a good practice not to use root user when you are connected to a network.
13-10-2006, 10:50 AM
#30 (permalink)
ok.doubt cleared regarding sudo.
I updated system with update manager and installed softs like azureus ,xmms player,VLC,downloader for x.
Ubuntu mounted all NTFS partitioned drives automatically.
Now i have one question that this data on NTFS partition is read only.
But I can play songs ,movies and even added downloaded data in azureus for uploading.Is there any problem doing so?
I used to use Odc for data transferring on lan for xp ?Now how can i transfer data ?
We were using Radmin like VNC. Is there any option for that?
__________
I downloaded rpm ,converted to debian package and installed
http://www.radmin.com/support/forum/...D=12&TID=10750
but it shows
bash: wine: command not found
