Old 01-10-2006, 03:47 PM   #1 (permalink)
executioner's Avatar
Exclamation A Big problem!!
Hi,
I have opensuse 10.1 installed with windows xp.Whenever i try to open a windows partition it shows "permission denied".I tried to mount it but it still says that.The partition is ntfs.what will i have to do supposing the partition name is multipurpose
executioner is offline
Old 01-10-2006, 03:50 PM   #2 (permalink)
18 Till I Die............
Default Re: A Big problem!!
Change the permissions in /etc/fstab
Just add umask=000 next to defaults in the line corrosponding to that partition.
http://www.bash.org/?258908
mehulved is offline
Old 01-10-2006, 03:59 PM   #3 (permalink)
could u explain that more clearly.i am a newbie.Please tell every step.
Old 01-10-2006, 07:30 PM   #4 (permalink)
GaurishSharma.com
gary4gar's Avatar
open ur terminal & enter
e.g. Assumed that /dev/hda1 is the location of Windows partition (NTFS)
Local mount folder: /media/windows also u must be un root
mkdir /mnt/windows
gedit /etc/fstab
Append the following line:
/dev/hda1    /mnt/windows ntfs  nls=utf8,umask=0222 0    0
gary4gar is offline
Old 01-10-2006, 08:21 PM   #5 (permalink)
JGuru's Avatar
@Gary, Suse Linux mounts Windows partitions automatically!! It mounts the Windows
partitions is the '/windows' directory. Just login as 'root' from the Terminal Window:
$ su -
(Enter root password)
# gedit /etc/fstab
Now make the changes , 'umask=0222' 0 0' at the end of the line
that corresponds to Windows partitions.
You must make the changes to all Windows partitions.
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
