Old 27-09-2006, 09:19 PM   #1 (permalink)
unni's Avatar
Unhappy K3B says device busy-cannot burn disks
Hi everybody,
I have been using Ubuntu 6.06 for the past few days. Initially K3B worked fine for me. But recently, I don't know what happened, I can't burn any CDs or DVDs. When I press burn or erase, it says that the device is busy. I am using GNOME. My DVD writer is Sony DVD-RW DRU-810A. Earlier, when I had tried to burn multisession CDs, K3B just froze my system. Then I had to reboot. I also had my kernel updated to the latest. I don't if any of this could be causing this problem. Please help. Gnomebaker is also saying that the device is busy. The output file is as below:
System
K3b Version: 0.12.17
KDE Version: 3.5.2
QT Version: 3.3.6
Kernel: 2.6.15-27-386
Devices
SONY DVD RW DRU-810A 1.0e (/dev/hdc, ) at /media/cdrom1 [CD-R; CD-RW; CD-ROM; DVD-ROM; DVD-R; DVD-RW; DVD-R DL; DVD+R; DVD+RW; DVD+R DL] [DVD-ROM; DVD-R Sequential; DVD-R Dual Layer Sequential; DVD-R Dual Layer Jump; DVD-RW Restricted Overwrite; DVD-RW Sequential; DVD+RW; DVD+R; DVD+R Double Layer; CD-ROM; CD-R; CD-RW] [SAO; TAO; RAW; SAO/R96R; RAW/R16; RAW/R96R; Restricted Overwrite; Layer Jump]
HL-DT-ST DVD-ROM GDR8163B 0L23 (/dev/hdd, ) at /media/cdrom0 [CD-ROM; DVD-ROM] [DVD-ROM; CD-ROM] [None]
Used versions
cdrecord: 2.1.1a01
cdrecord command:
/usr/bin/X11/cdrecord.mmap -v gracetime=2 dev=/dev/hdc speed=10 -tao driveropts=burnfree -eject blank=fast -force
cdrecord
/usr/bin/X11/cdrecord: Warning: Running on Linux-2.6.15-27-386
/usr/bin/X11/cdrecord: There are unsettled issues with Linux-2.5 and newer.
/usr/bin/X11/cdrecord: If you have unexpected problems, please try Linux-2.4 or Solaris.
scsidev: '/dev/hdc'
devname: '/dev/hdc'
scsibus: -2 target: -2 lun: -2
Warning: Open by 'devname' is unintentional and not supported.
Error trying to open /dev/hdc exclusively (Device or resource busy)... retrying in 1 second.
/usr/bin/X11/cdrecord: Device or resource busy. Cannot open '/dev/hdc'. Cannot open SCSI driver.
/usr/bin/X11/cdrecord: For possible targets try 'cdrecord -scanbus'. Make sure you are root.
/usr/bin/X11/cdrecord: For possible transport specifiers try 'cdrecord dev=help'.
/usr/bin/X11/cdrecord: For more information, install the cdrtools-doc
/usr/bin/X11/cdrecord: package and read /usr/share/doc/cdrecord/README.ATAPI.setup .
Cdrecord-Clone 2.01.01a01 (i686-pc-linux-gnu) Copyright (C) 1995-2004 Joerg Schilling
NOTE: this version of cdrecord is an inofficial (modified) release of cdrecord
and thus may have bugs that are not present in the original version.
Please send bug reports and support requests to <cdrtools@packages.debian.org>.
The original author should not be bothered with problems of this version.
TOC Type: 1 = CD-ROM
unni is offline
Old 27-09-2006, 11:02 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: K3B says device busy-cannot burn disks
Umm.. Are you accessing the drive anywhere else while burning?
kalpik is offline
Old 28-09-2006, 12:15 AM   #3 (permalink)
JGuru's Avatar
@Unni, Can you tell what Kernel packages you updated? Also give us your System
details- like Processor. motherboard etc., Also installing the wrong Kernel packages
can lead to big trouble!!
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
Old 28-09-2006, 12:21 AM   #4 (permalink)
El mooooo
eddie's Avatar
Its just that your cdrom is mounted at the time of writing. This is not allowed. Just unmount the drive using umount command and add "noauto" in your /etc/fstab file's cdrom line.
eddie is offline
Old 30-09-2006, 02:45 PM   #5 (permalink)
unni's Avatar
Good to see that the forum is up and running.
No. But it is automatically mounted and the link to the disk appears on the desktop.
Originally Posted by JGuru
Can you tell what Kernel packages you updated? Also give us your System details- like Processor. motherboard etc., Also installing the wrong Kernel packages can lead to big trouble!!
I updated kernel only through Synaptic Package Manager.
I checked the /etc/fstab file and guess what, there was no entry for my DVD writer. So I copied the line for my DVD drive and modified it and now K3B works as excepted. Thank you all.
Now, the real problem for which I want you guys' help. I had actually planned to ask this when the above problem came up.
I can burn a data CD or data DVD project on a fresh plain disk. However, when I try to burn a multisession CD by chosing Continue Multisession, the system just freezes, and then the only option left is a hard reboot. This also happens when I choose Disk Info. Once, I even had to reinstall Ubuntu because, after rebooting like this, the partition table got corrupted.
My system details are as follows:
Ubuntu 6.06 with all the available official updates
Intel 845GEBV2 motherboard
Intel Pentium 4 1.8GHz (32 bit) processor
256 MB DDR RAM
40 GB+80 GB Samsung HDDs
Sony DVDRW DRU-810A DVD Writer
LG DVD Drive
DLink DFE-520TX PCI 10/100Mbps LAN Card
Dax HSP56 Modem
NetMos PCI Serial Port Card
Creative SBLive 5.1 Sound Card
Is there any known reason for this problem? Please give me some suggestions.
unni is offline
Old 01-10-2006, 12:38 AM   #6 (permalink)
JGuru's Avatar
@Unni, you can try Nero Linux. It's a shareware. Download it from here
For Nero Linux User Guide Click here
Remember you must download the '.deb' file (since Ubuntu is based on Debian).
I haven't tried multisession CD burning in Linux.
-Albert Einstein
JGuru is offline
Old 01-10-2006, 09:27 AM   #7 (permalink)
18 Till I Die............
Ugh never recommend Nero Linux it's c**p.
Rather try out something like GNOMEBaker and see if it still causes the problem or does it work fine.
http://www.bash.org/?258908
mehulved is offline
Old 01-10-2006, 12:08 PM   #8 (permalink)
JGuru's Avatar
I know that @Mehul. Compared to it's Windows counterpart, 'NeroLinux' is just a shadow!!
Yes, 'K3B' & 'Gnomebaker' are defintely better than 'NeroLinux'.
-Albert Einstein
JGuru is offline
Old 06-10-2006, 08:56 PM   #9 (permalink)
unni's Avatar
Thank you all for trying to help me. Fortunately, GnomeBaker is working fine. Also, K3B shows the problem only when I try to import multisession CDs, not multisession DVDs.
unni is offline
Old 07-10-2006, 05:04 AM   #10 (permalink)
left this forum longback
praka123's Avatar
perhaps during the trouble session(s),u may try "lsof |grep cdrecord" to find what's jamming the app.also options include upgrading cdrecord to the new fork ``wodim``
praka123 is offline
Old 07-10-2006, 03:20 PM   #11 (permalink)
unni's Avatar
Its not just K3B, the entire computer is frozen.
Isn't GnomeBaker and K3B frontends to cdrecord? I am mentioning this because GnomeBaker is working fine while K3B has some trouble with multisession CDs (and not with multisession DVDs). What do you mean by new fork ``wodim`` ?
unni is offline
Old 07-10-2006, 04:01 PM   #12 (permalink)
JGuru's Avatar
@Unni, new fork wodim means 'cdrecord' is no longer supported, new tool
'wodim' will be used instead!! For more on that click here
-Albert Einstein
JGuru is offline
