Old 27-09-2006, 11:30 AM   #1 (permalink)
Tux Fan
shaunak's Avatar
Default Ubuntu installation help
I have two partitions on my HDD : a 10gb on on which vista is installed and a 65gb partition. i want to install ubuntu 6.x, how do i go about resizing and installing? i have got the iso file.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 27-09-2006, 12:01 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Ubuntu installation help
use a partition manager and create a ext3 nd a swap partition
Pathik is offline
Old 27-09-2006, 12:28 PM   #3 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Ubuntu installer will do the resizing automatically!
kalpik is offline
Old 27-09-2006, 02:35 PM   #4 (permalink)
Tux Fan
shaunak's Avatar
Actually i was asking which partition manager bet since the installer will do the resizing i guess that question is answered.
I have red hat 9 also [which i used to run before and am quite comfy with] should i install that, considering the comfort level or ubuntu?
another question will i loose data during resizing?
Cheers
Shaunak
shaunak is offline
Old 27-09-2006, 02:48 PM   #5 (permalink)
Beneath The Eyelids
The Outsider's Avatar
i say install ubuntu, as far as i know red hat 9 is like win 98 (old fart) lolz
rest simple method is go acronis.com and get the evaluation version of "Acronis Partition Expert" and resize your 65 gb partition in a way that 10GB is left Unpartitioned.
just run the partition expert properly, you won't lose any data.
and make the linux partitions through ubuntu installer on the 10 gb space you freed.
swap = 2*size of your ram and rest for root (/) volume
The Outsider is offline
Old 27-09-2006, 02:55 PM   #6 (permalink)
Tux Fan
shaunak's Avatar
Final few questions
>Any other rezizing alternatives[non trial]
>which boot loader?
>Kde or gnome?
Imm using 512 Mb ram with onboard intel 865 graphics.
Cheers
Shaunak
shaunak is offline
Old 27-09-2006, 03:01 PM   #7 (permalink)
Beneath The Eyelids
>anything you like, norton partition magic, paragon disk manager & not trial i think Gparted is the only one you can get, you need to download it and burn to a cd (not sure bout Gparted)
>Ubuntu will install Grub by default, you don't have to worry.
>Ubuntu has gnome as default and further you can install Kde online.
btw, Kde and XCFe rocks
with 512 mb ram make the swap like 950 mb, that will do.
Old 27-09-2006, 03:59 PM   #8 (permalink)
18 Till I Die............
Use any Desktop Environment/Window Manager you like, 512 MB is enough.
GRUB is good enough boot loader to dual boot with windows and it comes by defualt in ubuntu.
For partitioning purposes, IMO, fdisk which is used by linux distros is the best around. But, yeah it's rather a sharp tool, if you mess around much with no knowledge then you can loose information, but if you are just careful enough, there will be surely no problem in partitioning.
And don't forget swap partition of 750MB to 1GB.
http://www.bash.org/?258908
mehulved is offline
Old 27-09-2006, 04:13 PM   #9 (permalink)
kalpik's Avatar
The Ubuntu installer is very friendly while re-sizing (make sure u use the live CD to install). You will be able to choose the right settings very easily, and no data will be lost. The default is to resize the largest partition, which suits your case perfectly.. So dont worry!
kalpik is offline
