Old 25-09-2006, 06:08 PM   #1 (permalink)
anvesh's Avatar
Unhappy How to setup bluetooth DUN dial-up
I don't have BSNL or Reliance connection. I have activated mobile-office in airtel (bluetooth dial-up connection) and by this I m able to surf net on windows. I've tried to setup this in mandriva2006 but i couldn't. I was only able to send file from pc 2 mobile. So how can i setup internet on linux? I have ...
1.Ubuntu
2.Mandriva
3.Suse 10.1
I've tried only mandriva. Should i try suse or any other distro?
anvesh is offline
Old 25-09-2006, 07:28 PM   #2 (permalink)
sariq
Posts: n/a
Default Re: How to setup bluetooth DUN dial-up
see this thread:
Tutorial - internet through airtelgprs in Ubuntu
Old 25-09-2006, 09:08 PM   #3 (permalink)
anvesh's Avatar
@sariq I tried it but not working. It shows "No device found" msg. Is there any thing by which i can install bluetooth dongle?
anvesh is offline
Old 25-09-2006, 09:30 PM   #4 (permalink)
sariq
Posts: n/a
delete all previously paired devices in mobile, and search for new device from mobile. it should search your computer.
Old 26-09-2006, 11:11 AM   #5 (permalink)
anvesh's Avatar
Phone has detected pc bluetooth but couldn't able to paired with it. Can u tell me how to install new hardware on ubuntu?
anvesh is offline
Old 26-09-2006, 05:41 PM   #6 (permalink)
sariq
Posts: n/a
why ?
i have never found any problem in pairing with differentbluetooth donges/ mobiles. you may check your PIN from /etc/bluetooth/pin.txt . by default it is 1234
Old 27-09-2006, 05:41 PM   #7 (permalink)
FooBar Guy
GNUrag's Avatar
i havent tried this howto as i dont have a bluetooth device.
http://www.ubuntu-in.org/wiki/GPRS_Howto
http://web.gnuer.org
GNUrag is offline
Old 27-09-2006, 06:08 PM   #8 (permalink)
anvesh's Avatar
It is what sariq has written.
Can ne1 tell me how to install new hardware on ubuntu?
anvesh is offline
Old 27-09-2006, 08:27 PM   #9 (permalink)
18 Till I Die............
There's no need to install it. Kernel itself detects and loads the drivers.
I guess bluezutils must not have been started. Try issuing these commands in the terminal and see what happens
sudo /etc/init.d/bluez-utils start
hcitool scan
http://www.bash.org/?258908
mehulved is offline
Old 28-09-2006, 11:05 AM   #10 (permalink)
anvesh's Avatar
Now i m able to pair mobile with pc (with pin=1234). In ubuntu I right clicked on a file and selected "send to.. " option,and my phone's bluetooth was detected. But whenever i give command "hcitool scan" it gives "No such device found" msg.
I just want to enable multimedia in ubuntu, but cant connect 2 net. My net is working well with windows, is there any way by which i can download file from windows and install it on ubuntu? if yes then from which site and which files should i d'load?
anvesh is offline
Old 30-09-2006, 07:12 PM   #11 (permalink)
sariq
Posts: n/a
@anvesh: have you tried this - http://pratyeka.org/rfcomm/
(thanks to Jguru for the link)
