Old 14-09-2006, 12:15 PM   #1 (permalink)
The Linux Man !
paragkalra's Avatar
Thumbs up How to start Baghira
Hi guys and gals I downloaded Baghira (mac theme for linux) and intalled it using:
#./configure --prefix=`kde-config --prefix` --disable-debug
#make
#make install
It was sucessuflly installed. Now my querry is how to start Baghira theme...i mean der seems to be no icon like stuff...
Parag.A.Kalra, The Linux Man
http://www.paragkalra.com/
In this world without WALLS and GATES who need WINDOWS! USE LINUX! STOP PIRACY! GO OPEN SOURCE!
paragkalra is offline
Old 15-09-2006, 10:37 PM   #2 (permalink)
vignesh's Avatar
Default Re: How to start Baghira
There is an easier way mate.. Here are a few links I had collected before
http://www.freesoftwaremagazine.com/...ook?page=0%2C5
I saw another tutorial on a site. will tell you mate
vignesh is offline
Old 15-09-2006, 11:06 PM   #3 (permalink)
18 Till I Die............
Just check if yum has Baghira. I just checked up the portage for ubuntu. It's there. I just had to give command
sudo apt-get install kwin-baghira
http://www.bash.org/?258908
mehulved is offline
Old 17-09-2006, 01:32 AM   #4 (permalink)
El mooooo
eddie's Avatar
Open Control Center. Go to "Appearance & Themes --> Styles" and select Baghira from the list. Press Ok and the style will be changed. Similarly go to "Window Decorations" and do the same. You can configure some settings of Baghira style by clicking "Configure" button under Styles module.
To get "Baghira Starter", right click on your panel and choose "Add applet to panel". Choose Baghira Starter from the next window.
eddie is offline
Old 17-09-2006, 03:22 AM   #5 (permalink)
GaurishSharma.com
gary4gar's Avatar
check the typo
gary4gar is offline
