Old 10-09-2006, 01:23 PM   #1 (permalink)
desmond_315's Avatar
Default gcc toolchain building error...
i get the following error while building the toolchain
src/gcc-4.0-20060817/libiberty/regex.c:8242: error: dereferencing pointer to incomplete type
/src/gcc-4.0-20060817/libiberty/regex.c:8243: error: dereferencing pointer to incomplete type
/src/gcc-4.0-20060817/libiberty/regex.c:8244: error: dereferencing pointer to incomplete type
make[1]: *** [regex.o] Error 1
make[1]: Leaving directory `/tmp/build/gcc/arm-elf/libiberty'
make: *** [all-target-libiberty] Error 2
make: Leaving directory `/tmp/build/gcc'
please help..
desmond_315 is offline
Old 10-09-2006, 03:19 PM   #2 (permalink)
18 Till I Die............
Default Re: gcc toolchain building error...
What are you trying to compile there? I don't really know what the exact cause of the error is, but googling shows it is maybe due to using of different versions of gcc.
If you give more info on what is causing this error and which distro are you using, maybe it will be more helpful.
http://www.bash.org/?258908
mehulved is offline
Old 10-09-2006, 07:39 PM   #3 (permalink)
i have got fedora core five installed on my comp...i want to build a toolchain for an arm kit..for that im followin the procedure given at
http://ecos.sourceware.org/build-toolchain.html
but i have downloaded newer ver versions of binutils-2.16.92
gcc-core-4.0.tar
gcc-g++-4.0-20060817.tar
gdb-6.5.tar
i did this cause i was gettin errors usin the versions on the site n read somewhere that its cause fedora have a newer version of gcc...but im still gettin an errror when installin gcc.
Old 10-09-2006, 08:42 PM   #4 (permalink)
Well that's what I doubt. I think this toolchain for arm uses gcc 3.x. So, it requires gcc 3.x more specifically 3.2.x installed on your FC. Just install gcc 3.2.x that is available for FC 5. IMO, that should work for you.
mehulved is offline
Old 11-09-2006, 02:11 PM   #5 (permalink)
Hi,
Don't just download the newest tarballs and try to compile. They gave error always. Instead try to use a toolchain building tool like crosstool or so. They will download the matching tarball and then compile them.
CompBEe
jigslinx is offline
