Old 09-09-2006, 02:47 PM   #1 (permalink)
From Sri Lanka
thilina's Avatar
Default how to make DVD to mount automatically ???
I have a dvd rom.when I insert a dvd to it in windows the DVD works fine.But in ubuntu it is mounted as a blank DVD .I cant use it in any way.I cant use it to watch movies,to get data or anything.But in windows all goes well.
I found a command from ubuntu start guide to mount cd's manually.It is "sudo mount /media/cdrom0/ -o unhide" .When I input this command in terminal it gives this message "mount: block device /dev/hdb is write-protected, mounting read-only" .But the DVD gets mounted succesfully.So my question is this.Cant I set the DVD's to be mounted automatically after I insert them,rather than doing this typing in terminal??
thilina is offline
Old 09-09-2006, 05:58 PM   #2 (permalink)
18 Till I Die............
Default Re: how to make DVD to mount automatically ???
Have you tried passing these parameters in /etc/fstab?
Besides, if you do not want to see the 'mounting read only' message, pass ro also to options in fstab.
http://www.bash.org/?258908
mehulved is offline
Old 09-09-2006, 09:13 PM   #3 (permalink)
From Sri Lanka
thilina's Avatar
I am new to linux.Ill be glad if you explain me briefly plz
thilina is offline
Old 09-09-2006, 09:29 PM   #4 (permalink)
drsethi's Avatar
You cannot automount Cd or DVD in Linux. This is a security feature of Linux.
drsethi is offline
Old 09-09-2006, 09:49 PM   #5 (permalink)
Sorry drsethi, but it is possible to automount any media. Of course it is disabled by default and with a good reason. But, it is surely possible to enable it.
These links should help you understand more Open fstab file by the command
sudo nano /etc/fstab
Make the necessary changes and save it.
Then run this command
sudo mount -a
Also, read man page for more
man fstab
mehulved is offline
Old 09-09-2006, 09:54 PM   #6 (permalink)
From Sri Lanka
thilina's Avatar
But the CD's get auto mounted ???
__________
Ill chk the links
(I still dont understand anything !!)
thilina is offline
