Old 01-09-2006, 02:38 PM   #1 (permalink)
Level 96 Headbanger
DeSmOnD dAvId's Avatar
Default Problem with commands in FC4
I have a weird problem with FC4. The konsole does not recognise commands such as insmod, lsmod, chmod, fdisk, etc. What do you think is the cause of this problem? Also, can you tell the solution?
Thanks in Advance!
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium
(Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 (New :twisted:), Roland MicroCube Amp.
DeSmOnD dAvId is offline
Old 01-09-2006, 02:58 PM   #2 (permalink)
18 Till I Die............
Default Re: Problem with commands in FC4
DId you select softwares manually while installation? It seems the installation hasn't gone well. Just search for these in the CD/DVD and install it or install them from net.
Also, see if you can get these commands to work as root?
http://www.bash.org/?258908
mehulved is offline
Old 01-09-2006, 08:24 PM   #3 (permalink)
left this forum longback
praka123's Avatar
Smile Re: Problem with commands in FC4
try as root:
prakash@localhost.localdomain:~# system-config-packages
and get the needed pkgs installed.(devel tools)
praka123 is offline
Old 02-09-2006, 11:57 AM   #4 (permalink)
Level 96 Headbanger
Yeah, I manually selected the packages to install. However, I cant get the commands to work even as root. What extra package do you think will be required?
Steam : DeathMetal
Old 02-09-2006, 01:27 PM   #5 (permalink)
String Phreak
mediator's Avatar
may be the commands are not in path!
command from root "locate chmod" and similarly for others and then add their directory to path!
neways chmod is in "bin directory".....so try "/bin/chmod"
If it doesnt work then probably the packages are not installed!
mediator is offline
Old 02-09-2006, 01:50 PM   #6 (permalink)
I see right through you.
Sykora's Avatar
The commands you have listed are part of coreutils : http://www.gnu.org/software/coreutil...coreutils.html , so it is inconceivable that your system is operating without coreutils installed. Go as root and type "which chmod", or like mediator said, "locate chmod". Also try it in virtual terminal mode, or using sudo.
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 06-09-2006, 01:30 PM   #7 (permalink)
Level 96 Headbanger
Sorry, chmod is working fine, I have problems with insmod, lspci, fdisk and such commands. I have found these commands in /sbin but not in usr/sbin. I tried copying the files to this folder, but no use. They dont work as root.
Steam : DeathMetal
Old 06-09-2006, 02:27 PM   #8 (permalink)
What is the output of
echo $PATH
mehulved is offline
Old 07-09-2006, 11:19 AM   #9 (permalink)
Level 96 Headbanger
echo $PATH
Heres the output exactly as displayed.
[desmond@localhost /]$ echo $PATH
/usr/kerberos/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/desmond/bin
Steam : DeathMetal
Old 07-09-2006, 06:42 PM   #10 (permalink)
Sykora's Avatar
You have to add /sbin to your path, if you want to use these tools. They're put in /sbin because it is forseen that only root user will want to use these tools.
-- Sykora --
Sykora is offline
Old 08-09-2006, 12:47 PM   #11 (permalink)
Level 96 Headbanger
So, what should I do to make them available to the user (i.e. myself)
Steam : DeathMetal
Old 08-09-2006, 03:00 PM   #12 (permalink)
First see if adding the following line in /etc/bash.bashrc.local helps out
PATH=$PATH:/sbin
mehulved is offline
Old 07-10-2006, 05:39 PM   #13 (permalink)
Level 96 Headbanger
The command works. I am temporarily able to use the commands for one session. However, I am not able to find the file /etc/bash.bashrc.local , do I have to create it?
Steam : DeathMetal
Old 07-10-2006, 07:24 PM   #14 (permalink)
Umm I am not so familar with FC, maybe you could look up in their docs or search up on the net, something similar should be there.
mehulved is offline
Old 07-10-2006, 07:45 PM   #15 (permalink)
Sykora's Avatar
You can add the command in your ~/.bashrc file. It's got to be there. Otherwise, it'll be called ~/.bash-profile or something like that.
-- Sykora --
Sykora is offline
Old 07-10-2006, 08:39 PM   #16 (permalink)
JGuru's Avatar
@Desmond, the files .bashrc, .bash_profile are hidden files!!!
They are in your home directory. For eg., if your Login name is desmond , then
your home is /home/desmond. You can view the hidden files in GNOME , from the
menu 'View'->'Show Hidden files' (Ctrl + H). Another way to view them is from
the Terminal Window, type:
$ ls -al
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
