Old 31-08-2006, 12:24 AM   #1 (permalink)
SE><IE
Posts: n/a
Unhappy How to start GUI in SOLARIS
I recently installed SOLARIS 10 and it logged me IN automatically as "root". I wanna know how to start the GUI shell. Ma sys is P-4 3.2 with 512 DDR 266 RAM
The steps that show up are
grub loading stage2...
<options> (bootmenu)
1)Solaris 10 1/06 s10x_u1wos_19a x86
2)solaris fail (something like that-yaad nahi)
3)windows
1 pe enter mara and licence screen showed up.
Hostname : satyam-9665 (I entered it earlier)
checking ufs filesystem
Satyam-9665 console login
aug(date n time) Satyam-9665 sendmail[372]:My unqualified host name(local host) unknown; sleeping for retry
Starting desktop login on display:0
wait for the Desktop screen before logging in
The X Server can not be started on display:0
The screen flickered a bit here
aug(date n time) Satyam-9665 sendmail[315]:My unqualified my own domain name(local host) --using short name
After this I was in the terminal/console as "root"
Old 31-08-2006, 01:50 AM   #2 (permalink)
The Lord of Death
Yamaraj's Avatar
Default Re: How to start GUI in SOLARIS
GUI always starts automatically in Solaris, unless disabled by root. In your case,
the graphics card seems to be having problems. Execute kdmconfig as root and
follow the instructions. You may also have to configure X manually, depending
on your card.
Did you do a full install of Solaris? For more help, join #solaris on freenode.
Yamaraj is offline
Old 31-08-2006, 10:07 PM   #3 (permalink)
SE><IE
Posts: n/a
Yes I did a full install and hence it took appx 10 GB.
where's it?
Old 31-08-2006, 10:17 PM   #4 (permalink)
The Lord of Death
Yamaraj's Avatar
irc.freenode.net
Yamaraj is offline
Old 31-08-2006, 11:14 PM   #5 (permalink)
SE><IE
Posts: n/a
The link is not working.
I went to http://irc.freenode.net/ and it showed up
Not Found
The requested URL / was not found on this server.
Apache Server at irc.freenode.net Port 80
do I need to register somewhere or what. please guide me
Old 31-08-2006, 11:28 PM   #6 (permalink)
18 Till I Die............
IRC cannot be opened in the browser like a url. It's something like chatting on messengers.
Some info on irc can be obtained here Digit Unofficial Chat-Room [IRC] and http://www.irchelp.org/irchelp/faq.html
http://www.bash.org/?258908
mehulved is offline
Old 01-09-2006, 12:20 AM   #7 (permalink)
SE><IE
Posts: n/a
Hmm.. thanks got Chatzilla and some help too
thanks yamaraj and tech_your_future
Old 01-09-2006, 05:43 PM   #8 (permalink)
Commander in Chief
QwertyManiac's Avatar
Mention the solution here if possible too
Harsh J
www.harshj.com
QwertyManiac is offline
Old 01-09-2006, 09:53 PM   #9 (permalink)
SE><IE
Posts: n/a
Well most of them said its a problem with the graphics card. I suspected this too coz just as solaris tries to load the GUI shell, the screen flickered 4 times (with a gap of 2-3 secs). I assume it was that solaris was tried to load the GUI shell but was unable to do so.
Another reasona may be that some installation files were missing. Thats because just before the disc-1 was going to end some errors showed up (missing files). May be these files were responible for proper working of the GUI shell and hence the problem.
This time I will configure the installing options manually and will post the results here
