Old 25-08-2006, 08:24 PM   #1 (permalink)
From Sri Lanka
thilina's Avatar
Default DVD mount problem
No matter what kind of a DVD I insert to my DVD rom Fedora core(ver.4) & Ubuntu(ver.5) both identifies it as a blank DVD-rom.How can I fix this prolem??
This isnt happening in Win xp.my rom works fine in Win xp.
thilina is offline
Old 25-08-2006, 09:57 PM   #2 (permalink)
18 Till I Die............
Default Re: DVD mount problem
Try installing libdvdcss and see if that solves the problem.
http://www.bash.org/?258908
mehulved is offline
Old 26-08-2006, 12:41 AM   #3 (permalink)
El mooooo
eddie's Avatar
After inserting your DVD in your drive and waiting for at least 1 minute, try to access your drive. If it does not work, give us output of "dmesg" and "cat /etc/mtab" (both without quotes) commands.
eddie is offline
Old 26-08-2006, 06:31 PM   #4 (permalink)
From Sri Lanka
thilina's Avatar
from where to get it??
__________
out put 4 dmesg
ishan@ubuntu:~$ dmesg
I resources starting at 0f800000 (gap: 0f800000:f06e0000)
[4294667.296000] Built 1 zonelists
[4294667.296000] Kernel command line: root=/dev/hda7 ro quiet splash
[4294667.296000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[4294667.296000] mapped APIC to ffffd000 (011f1000)
[4294667.296000] Initializing CPU#0
[4294667.296000] PID hash table entries: 1024 (order: 10, 16384 bytes)
[4294667.296000] Detected 1793.159 MHz processor.
[4294667.296000] Using pmtmr for high-res timesource
[4294667.296000] Console: colour VGA+ 80x25
[4294671.252000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)[4294671.253000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[4294671.261000] Memory: 243588k/253888k available (1415k kernel code, 9688k reserved, 763k data, 224k init, 0k highmem)
[4294671.261000] Checking if this processor honours the WP bit even in supervisor mode... Ok.
[4294671.261000] Calibrating delay loop... 3555.32 BogoMIPS (lpj=1777664)
[4294671.283000] Security Framework v1.0.0 initialized
[4294671.283000] SELinux: Disabled at boot.
[4294671.283000] Mount-cache hash table entries: 512
[4294671.283000] CPU: After generic identify, caps: 3febf9ff 00000000 00000000 00000000 00000000 00000000 00000000
[4294671.283000] CPU: After vendor identify, caps: 3febf9ff 00000000 00000000 00000000 00000000 00000000 00000000
[4294671.283000] CPU: Trace cache: 12K uops, L1 D cache: 8K
[4294671.283000] CPU: L2 cache: 256K
[4294671.283000] CPU: After all inits, caps: 3febf9ff 00000000 00000000 00000080 00000000 00000000 00000000
[4294671.283000] CPU: Intel(R) Pentium(R) 4 CPU 1.80GHz stepping 03
[4294671.283000] Enabling fast FPU save and restore... done.
[4294671.283000] Enabling unmasked SIMD FPU exception support... done.
[4294671.283000] Checking 'hlt' instruction... OK.
[4294671.287000] Checking for popad bug... OK.
[4294671.287000] checking if image is initramfs... it is
[4294671.903000] Freeing initrd memory: 4821k freed
[4294671.905000] ACPI: Looking for DSDT in initrd... not found!
[4294671.967000] not found!
[4294671.976000] ACPI: setting ELCR to 0200 (from 0820)
[4294672.188000] NET: Registered protocol family 16
[4294672.188000] EISA bus registered
[4294672.188000] ACPI: bus type pci registered
[4294672.190000] PCI: PCI BIOS revision 2.10 entry at 0xfdb01, last bus=2
[4294672.190000] PCI: Using configuration type 1
[4294672.190000] mtrr: v2.0 (20020519)
[4294672.191000] ACPI: Subsystem revision 20050729
[4294672.200000] ACPI: Interpreter enabled
[4294672.200000] ACPI: Using PIC for interrupt routing
[4294672.201000] ACPI: PCI Root Bridge [PCI0] (0000:00)
[4294672.201000] PCI: Probing PCI hardware (bus 00)
[4294672.201000] ACPI: Assume root bridge [\_SB_.PCI0] segment is 0
[4294672.204000] Uncovering SIS962 that hid as a SIS503 (compatible=1)
[4294672.204000] Enabling SiS 96x SMBus.
[4294672.205000] Boot video device is 0000:01:00.0
[4294672.207000] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[4294672.212000] ACPI: Power Resource [URP1] (off)
[4294672.212000] ACPI: Power Resource [URP2] (off)
[4294672.212000] ACPI: Power Resource [FDDP] (off)
[4294672.212000] ACPI: Power Resource [LPTP] (off)
[4294672.213000] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 7 10 11 12 14 15)
[4294672.214000] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[4294672.214000] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 10 *11 12 14 15)
[4294672.214000] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[4294672.215000] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 7 10 11 12 14 15)
[4294672.215000] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 10 *11 12 14 15)
[4294672.215000] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 *11 12 14 15)
[4294672.216000] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 *11 12 14 15)
[4294672.216000] Linux Plug and Play Support v0.97 (c) Adam Belay
[4294672.216000] pnp: PnP ACPI init
[4294672.221000] pnp: PnP ACPI: found 11 devices
[4294672.221000] PnPBIOS: Disabled by ACPI PNP
[4294672.221000] PCI: Using ACPI for IRQ routing
[4294672.221000] PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
[4294672.240000] audit: initializing netlink socket (disabled)
[4294672.240000] audit: initialized
[4294672.240000] VFS: Disk quotas dquot_6.5.1
[4294672.240000] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[4294672.240000] devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
[4294672.240000] devfs: boot_options: 0x0
[4294672.240000] Initializing Cryptographic API
[4294672.240000] isapnp: Scanning for PnP cards...
[4294672.594000] isapnp: No Plug & Play device found
[4294672.629000] PNP: PS/2 Controller [PNP030bS2K,PNP0f03S2M] at 0x60,0x64 irq 1,12
[4294672.629000] serio: i8042 AUX port at 0x60,0x64 irq 12
[4294672.629000] serio: i8042 KBD port at 0x60,0x64 irq 1
[4294672.629000] Serial: 8250/16550 driver $Revision: 1.90 $ 54 ports, IRQ sharing enabled
[4294672.629000] ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[4294672.633000] ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[4294672.634000] io scheduler noop registered
[4294672.634000] io scheduler anticipatory registered
[4294672.634000] io scheduler deadline registered
[4294672.634000] io scheduler cfq registered
[4294672.634000] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
[4294672.635000] EISA: Probing bus 0 at eisa.0
[4294672.635000] EISA: Detected 0 cards.
[4294672.635000] NET: Registered protocol family 2
[4294672.644000] IP: routing cache hash table of 2048 buckets, 16Kbytes
[4294672.644000] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[4294672.644000] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[4294672.644000] TCP: Hash tables configured (established 8192 bind 8192)
[4294672.644000] NET: Registered protocol family 8
[4294672.644000] NET: Registered protocol family 20
[4294672.644000] ACPI wakeup devices:
[4294672.644000] PCI0 PS2M PS2K UAR1 USB1 USB2 USB3 USB4 S139 LAN MDM AUD SLPB
[4294672.644000] ACPI: (supports S0 S1 S4 S5)
[4294672.645000] Freeing unused kernel memory: 224k freed
[4294672.678000] vga16fb: initializing
[4294672.678000] vga16fb: mapped to 0xc00a0000
[4294672.772000] Console: switching to colour frame buffer device 80x30
[4294672.772000] fb0: VGA16 VGA frame buffer device
[4294672.772000] input: AT Translated Set 2 keyboard on isa0060/serio0
[4294673.864000] Capability LSM initialized
[4294673.883000] NET: Registered protocol family 1
[4294673.904000] Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
[4294673.904000] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[4294673.904000] ACPI: bus type ide registered
[4294673.916000] SIS5513: IDE controller at PCI slot 0000:00:02.5
[4294673.916000] SIS5513: chipset revision 0
[4294673.916000] SIS5513: not 100% native mode: will probe irqs later
[4294673.916000] SIS5513: SiS 962/963 MuTIOL IDE UDMA133 controller
[4294673.916000] ide0: BM-DMA at 0xff00-0xff07, BIOS settings: hdaMA, hdbMA
[4294673.916000] ide1: BM-DMA at 0xff08-0xff0f, BIOS settings: hdcMA, hddMA
[4294673.916000] Probing IDE interface ide0...
[4294674.180000] hda: Maxtor 2F040L0, ATA DISK drive
[4294674.588000] hdb: DVD-ROM 16X, ATAPI CD/DVD-ROM drive
[4294674.639000] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[4294674.639000] Probing IDE interface ide1...
[4294675.158000] Probing IDE interface ide1...
[4294675.677000] Probing IDE interface ide2...
[4294676.189000] Probing IDE interface ide3...
[4294676.701000] Probing IDE interface ide4...
[4294677.213000] Probing IDE interface ide5...
[4294677.731000] hda: max request size: 128KiB
[4294679.318000] hda: 80293248 sectors (41110 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(133)
[4294679.318000] hda: cache flushes supported
[4294679.318000] /dev/ide/host0/bus0/target0/lun0: p1 p2 < p5 p6 p7 > p3
[4294679.435000] hdb: ATAPI 32X DVD-ROM drive, 256kB Cache
[4294679.435000] Uniform CD-ROM driver Revision: 3.20
[4294681.894000] Attempting manual resume
[4294681.894000] swsusp: Suspend partition has wrong signature?
[4294681.971000] usbcore: registered new driver usbfs
[4294681.971000] usbcore: registered new driver hub
[4294681.972000] ohci_hcd: 2004 Nov 08 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
[4294681.972000] ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 5
[4294681.972000] PCI: setting IRQ 5 as level-triggered
[4294681.972000] ACPI: PCI Interrupt 0000:00:03.0[A] -> Link [LNKE] -> GSI 5 (level, low) -> IRQ 5
[4294681.972000] ohci_hcd 0000:00:03.0: Silicon Integrated Systems [SiS] USB 1.0 Controller
[4294681.973000] ohci_hcd 0000:00:03.0: new USB bus registered, assigned bus number 1
[4294681.973000] ohci_hcd 0000:00:03.0: irq 5, io mem 0xdfff8000
[4294681.986000] hub 1-0:1.0: USB hub found
[4294681.986000] hub 1-0:1.0: 2 ports detected
[4294681.989000] ACPI: PCI Interrupt Link [LNKF] enabled at IRQ 11
[4294681.989000] PCI: setting IRQ 11 as level-triggered
[4294681.989000] ACPI: PCI Interrupt 0000:00:03.1[B] -> Link [LNKF] -> GSI 11 (level, low) -> IRQ 11
[4294681.989000] ohci_hcd 0000:00:03.1: Silicon Integrated Systems [SiS] USB 1.0 Controller (#2)
[4294681.989000] ohci_hcd 0000:00:03.1: new USB bus registered, assigned bus number 2
[4294681.989000] ohci_hcd 0000:00:03.1: irq 11, io mem 0xdfff9000
[4294682.002000] hub 2-0:1.0: USB hub found
[4294682.002000] hub 2-0:1.0: 2 ports detected
[4294682.005000] ACPI: PCI Interrupt Link [LNKG] enabled at IRQ 11
[4294682.005000] ACPI: PCI Interrupt 0000:00:03.2[C] -> Link [LNKG] -> GSI 11 (level, low) -> IRQ 11
[4294682.005000] ohci_hcd 0000:00:03.2: Silicon Integrated Systems [SiS] USB 1.0 Controller (#3)
[4294682.005000] ohci_hcd 0000:00:03.2: new USB bus registered, assigned bus number 3
[4294682.005000] ohci_hcd 0000:00:03.2: irq 11, io mem 0xdfffa000
[4294682.018000] hub 3-0:1.0: USB hub found
[4294682.018000] hub 3-0:1.0: 2 ports detected
[4294682.055000] ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 11
[4294682.055000] ACPI: PCI Interrupt 0000:00:03.3[D] -> Link [LNKH] -> GSI 11 (level, low) -> IRQ 11
[4294682.055000] ehci_hcd 0000:00:03.3: Silicon Integrated Systems [SiS] USB 2.0 Controller
[4294682.055000] ehci_hcd 0000:00:03.3: new USB bus registered, assigned bus number 4
[4294682.055000] ehci_hcd 0000:00:03.3: irq 11, io mem 0xdfffb000
[4294682.055000] PCI: cache line size of 128 is not supported by device 0000:00:03.3
[4294682.055000] ehci_hcd 0000:00:03.3: USB 2.0 initialized, EHCI 1.00, driver 10 Dec 2004
[4294682.055000] hub 4-0:1.0: USB hub found
[4294682.055000] hub 4-0:1.0: 6 ports detected
[4294682.062000] usb 1-1: new full speed USB device using ohci_hcd and address 2[4294682.973000] usb 1-1: new full speed USB device using ohci_hcd and address 3[4294684.115000] SCSI subsystem initialized
[4294684.117000] Initializing USB Mass Storage driver...
[4294684.119000] scsi0 : SCSI emulation for USB Mass Storage devices
[4294684.119000] usb-storage: device found at 3
[4294684.119000] usb-storage: waiting for device to settle before scanning
[4294684.119000] usbcore: registered new driver usb-storage
[4294684.119000] USB Mass Storage support registered.
[4294684.861000] ACPI: CPU0 (power states: C1[C1])
[4294685.062000] Attempting manual resume
[4294685.085000] swsusp: Suspend partition has wrong signature?
[4294685.128000] kjournald starting. Commit interval 5 seconds
[4294685.128000] EXT3-fs: mounted filesystem with ordered data mode.
[4294686.511000] md: md driver 0.90.1 MAX_MD_DEVS=256, MD_SB_DISKS=27
[4294689.124000] Vendor: KYE Model: Genius Rev: 0100
[4294689.124000] Type: Direct-Access ANSI SCSI revision: 04
[4294689.174000] usb-storage: device scan complete
[4294691.455000] SCSI device sda: 496128 512-byte hdwr sectors (254 MB)
[4294691.461000] sda: Write Protect is off
[4294691.461000] sda: Mode Sense: 38 00 00 00
[4294691.461000] sda: assuming drive cache: write through
[4294691.487000] SCSI device sda: 496128 512-byte hdwr sectors (254 MB)
[4294691.494000] sda: Write Protect is off
[4294691.494000] sda: Mode Sense: 38 00 00 00
[4294691.494000] sda: assuming drive cache: write through
[4294691.494000] /dev/scsi/host0/bus0/target0/lun0: p1
[4294691.506000] Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
thilina is offline
Old 26-08-2006, 09:14 PM   #5 (permalink)
From Sri Lanka
thilina's Avatar
[4294691.800000] Adding 465844k swap on /dev/hda3. Priority:-1 extents:1
[4294692.081000] EXT3 FS on hda7, internal journal
[4294698.895000] parport: PnPBIOS parport detected.
[4294698.895000] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[4294698.987000] lp0: using parport0 (interrupt-driven).
[4294699.028000] mice: PS/2 mouse device common for all mice
[4294699.433000] input: ImPS/2 Generic Wheel Mouse on isa0060/serio1
[4294699.840000] ts: Compaq touchscreen protocol output
[4294702.422000] device-mapper: 4.4.0-ioctl (2005-01-12) initialised: dm-devel@redhat.com
[4294705.700000] NTFS driver 2.1.22 [Flags: R/O MODULE].
[4294705.789000] NTFS volume version 3.1.
[4294705.901000] ext3: No journal on filesystem on hda6
[4294707.955000] Linux agpgart interface v0.101 (c) Dave Jones
[4294707.971000] agpgart: Detected SiS 650 chipset
[4294707.997000] agpgart: AGP aperture is 128M @ 0xe0000000
[4294708.156000] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[4294708.175000] shpchp: shpc_init : shpc_cap_offset == 0
[4294708.175000] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[4294708.402000] i2c-sis96x version 1.0.0
[4294708.409000] sis96x_smbus 0000:00:02.1: SiS96x SMBus base address: 0x0c00
[4294708.822000] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
[4294708.822000] ACPI: PCI Interrupt 0000:00:02.7[C] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
[4294709.130000] intel8x0_measure_ac97_clock: measured 49793 usecs
[4294709.130000] intel8x0: clocking to 48000
[4294711.552000] Real Time Clock Driver v1.12
[4294711.634000] input: PC Speaker
[4294711.996000] Floppy drive(s): fd0 is 1.44M
[4294712.011000] FDC 0 is a post-1991 82077
[4294715.511000] ACPI: Power Button (FF) [PWRF]
[4294715.511000] ACPI: Power Button (CM) [PWRB]
[4294715.511000] ACPI: Sleep Button (CM) [SLPB]
[4294715.682000] ibm_acpi: ec object not found
[4294730.619000] apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
[4294730.619000] apm: overridden by ACPI.
[4294732.569000] Bluetooth: Core ver 2.7
[4294732.569000] NET: Registered protocol family 31
[4294732.569000] Bluetooth: HCI device and connection manager initialized
[4294732.569000] Bluetooth: HCI socket layer initialized
[4294732.629000] Bluetooth: L2CAP ver 2.7
[4294732.629000] Bluetooth: L2CAP socket layer initialized
[4294732.660000] Bluetooth: RFCOMM ver 1.5
[4294732.660000] Bluetooth: RFCOMM socket layer initialized
[4294732.660000] Bluetooth: RFCOMM TTY layer initialized
[4294762.294000] NET: Registered protocol family 10
[4294762.294000] Disabled Privacy Extensions on device c02eb280(lo)
[4294762.295000] IPv6 over IPv4 tunneling driver
[4294772.610000] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[4294779.997000] ISO 9660 Extensions: Microsoft Joliet Level 3
[4294780.003000] ISOFS: changing to secondary root
[4294856.901000] CSLIP: code copyright 1989 Regents of the University of California
[4294856.957000] PPP generic driver version 2.4.2
[4294865.393000] PPP BSD Compression module registered
[4294865.461000] PPP Deflate Compression module registered
[4295323.491000] ext3: No journal on filesystem on hda6
[4295618.264000] cdrom: This disc doesn't have any tracks I recognize!
ishan@ubuntu:~$
__________
output for second command
/dev/hda7 / ext3 rw,errors=remount-ro 0 0
proc /proc proc rw 0 0
sysfs /sys sysfs rw 0 0
devpts /dev/pts devpts rw,gid=5,mode=620 0 0
tmpfs /dev/shm tmpfs rw 0 0
usbfs /proc/bus/usb usbfs rw 0 0
tmpfs /lib/modules/2.6.12-9-386/volatile tmpfs rw,mode=0755 0 0
/dev/hda1 /media/windows ntfs rw,umask=0222 0 0
/dev/hda5 /media/games vfat rw,umask=000 0 0
tmpfs /dev tmpfs rw,size=10M,mode=0755 0 0
/dev/sda1 /media/usbdisk vfat rw,noexec,nosuid,nodev,quiet,shortname=winnt,uid=1 000,gid=1000,umask=077,iocharset=utf8 0 0
__________
now what??
Can you solve the problem??
__________
Hey,why dont give me a reply???????????/
thilina is offline
Old 27-08-2006, 12:37 AM   #6 (permalink)
El mooooo
eddie's Avatar
What is written on this DVD? Is it a DVD with movie on it or some other data? If it is a movie DVD then try playing it with Xine instead of trying to mount it.
eddie is offline
Old 27-08-2006, 01:18 AM   #7 (permalink)
From Sri Lanka
thilina's Avatar
i used a dvd playing software in ubuntu to read DVD video disk
It worked
But data diska are identified as blank ones!!
Even the DVD videos are identified as blank ones
But they can be played in fvf playing softwares
thilina is offline
Old 27-08-2006, 01:24 AM   #8 (permalink)
El mooooo
eddie's Avatar
The dmesg output you posted...is it after you insert a movie DVD or after you inserted data DVD? Did you try to mount the data DVDs manually? You don't need to mount video DVDs and Audio CDs cos they are played without mounting.
eddie is offline
Old 27-08-2006, 01:30 AM   #9 (permalink)
From Sri Lanka
thilina's Avatar
After i inserted adata dvd
I tried to mount a data dvd manually but waz unsuccesfull
thilina is offline
Old 29-08-2006, 09:29 PM   #10 (permalink)
From Sri Lanka
thilina's Avatar
Angry Re: DVD mount problem
I tried playing a DVD movie via Totem player but it gives this message
"Failed to find mountpoint for device /dev/hdb in /etc/fstab"
I tried playing a DVD movie via both ogle & oKle players.But both of them stops responding .
VLC player does nothing when I try to play.
What the hell is this problem?????
thilina is offline
