Old 24-08-2006, 11:35 PM   #1 (permalink)
Unhappy Unfortunate Tum Trainer. Help
As A Redhat Linux 9 Tux Trainer, I Made It Cry Mp3 Using A Plugin.but To Play It With Video, I Installed Vlc Media Etc.but Alas The Tux Hide Those Players Somewhere.how Can I Use Them Without Seeing Anything.nothing In The Task Bar, Nothing In The Start Menu.nothing .vast Empty Space. Help Me Help Me
aleena1 is offline
Old 25-08-2006, 12:47 AM   #2 (permalink)
JGuru's Avatar
Default Re: Unfortunate Tum Trainer. Help
@Aleena, If you have installed VLC with all it's dependencies. Then this should work. Open the Terminal WIndow (similar to Console in Windows). Type:
$ vlc
This should load the VLC Media player.
I hope this helps.
JGuru is offline
