Old 23-08-2006, 06:22 PM   #1 (permalink)
Default Problem with FC5 installation
I was recently installing Fedora Core 5, and got this error after the anaconda starts to install after getting the language options. It says that the hda is not initialised. then asks if it shud delete all data
DON'T YOU DARE CLICK THIS : http://kevan.org/brain.cgi?the.unforgiven
Ultimate Z Fighter is offline
Old 23-08-2006, 08:51 PM   #2 (permalink)
abhishekkulkarni's Avatar
Default Re: Problem with FC5 installation
Please elaborate on the error ..
It asks if it should delete all data ??!!??
May the source be with you ..
abhishekkulkarni is offline
Old 23-08-2006, 09:14 PM   #3 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
that happens if it cannot understand the partition table. do no select delete all as this would empty ur hdd and make a new partition table...
Rollercoaster is offline
Old 24-08-2006, 12:53 AM   #4 (permalink)
JGuru's Avatar
That looks like another bug in Fedora!!
JGuru is offline
Old 24-08-2006, 01:41 AM   #5 (permalink)
GaurishSharma.com
gary4gar's Avatar
i got the same bug on setup on understanding my partion table when i installed through ubuntu desktop cd's.
gary4gar is offline
Old 24-08-2006, 08:52 AM   #6 (permalink)
nach p's Avatar
My FC5 bootin process is damn slow and after bootin it takes nearly 5 min. for getting start for an application.IS it a bug or hardware incompatabality.
but same things on RHEL4 works smoothly.So stopped using Fedora.
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
nach p is offline
Old 24-08-2006, 09:03 AM   #7 (permalink)
^ update ur kernel to the latest one. it will solve the problem
