Old 23-08-2006, 02:10 AM   #1 (permalink)
quantum's Avatar
Lightbulb linux trouble pros help me
hi their everyone
im a newbie here n also a newone to linux i installed ubuntu frm dvd i got frm digt installing was no problem i had a dual boot option for windows xp sp2
cause im new to linux
but suddenly after installation my broadband was acting strange
working as if it were a dial up connection a mere 5 mb download became heavy
could this be due to linux and windows both co existing
or was it just due to some coincidence n my cable is distorted
for now i have installed windows again n formatted linux partitions
connection seems to be better again kind of
plz reply u guys r using linux n i am greatly interested but not on cost of my bandwidth plz do help
quantum is offline
Old 23-08-2006, 07:39 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: linux trouble pros help me
the connection cant be slow due to ubuntu.. 4 more wait till jguru or tyf come here
Pathik is offline
Old 23-08-2006, 08:12 AM   #3 (permalink)
I see right through you.
Sykora's Avatar
This is interesting. When I installed linux, my internet speed increased, not decreased. But then, my speed is ridiculous anyway.
Let's see. It's highly unlikely that linux installation is influencing the speed of your broadband in windows. Linux doesn't intrude that way. I don't know if it's a coincidence. If you want to experiment, install only ubuntu, and see what happens.
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 23-08-2006, 08:28 AM   #4 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
there ia no corelation between no. of OS and download speeds. it is totally independent of each other.
u r telling me that after installing linux ur broadband suffered. this is impossible. another OS does not interfere with the one running. the are completely different entities.
__________
the problem must me with ur ISP. unless u modified soem hardware settings of ur modem/router from either linux or windows.
Last edited by Rollercoaster; 23-08-2006 at 08:29 AM. Reason: Automerged Doublepost
Rollercoaster is offline
Old 23-08-2006, 08:31 AM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
No, that cant be at all. I think what you say is right, its your line or maybe your modem. Also since the linux partitions were unidentified by windows it leaves them in peace, no issues what so ever. Can you try again please ?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 23-08-2006, 10:42 AM   #6 (permalink)
18 Till I Die............
There is no reason whatsoever that linux, windows or any other OS for that matter can affect your connection speed.
It could just be that it was a co-incidence or you configured something really badly.
BTW, which broadband are you using? I haven't really heard of any broadband giving such a bad speed. At the most I have heard is that of pacenet connection limits data transfer rate or linux dialer to around about 20kbps instead of 30 kbps.
Maybe you can tell which ISP you have and how did you configure your net. Also, you have connected via USB or LAN Card.
Also, I guess you were using Ubuntu 5.10, which is outdated, try to obtain 6.06 which is newer and has support for longer term.
http://www.bash.org/?258908
mehulved is offline
