Old 22-08-2006, 05:14 PM   #1 (permalink)
!FREEWARES!
Akshay's Avatar
Default Will Suse 10.1 run on 3.06 ghz P4 64-bit
My friend is not able to install suse 10.1. He is using P4 3.06 ghz 64-bit. The installation stops after this msg: optimum mode 1280x1024 at 60 hz
just this message with a blank screen.
How to overcome this prb?
Thnx
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 22-08-2006, 05:37 PM   #2 (permalink)
18 Till I Die............
Default Re: Will Suse 10.1 run on 3.06 ghz P4 64-bit
That's a problem with screen resoultion settings. Unfortunately I get it too a few days back when installing SLED 10. I had to resort to manually editing the Xorg.conf file.
Well he can try
xorgconfig
and set screen resolution to 800x600. Once he can get into GUI, he can then configure resolution using SaX2 from KMenu => System => Configuration =>SaX2.
http://www.bash.org/?258908
mehulved is offline
