Old 06-12-2004, 07:57 PM   #1 (permalink)
Default Problem with SUSE 9.1
hello guys,
I got a P4 2.8 GHz machine with an 80gb hdd and 512mb ram.its got winXP on it and i wanted to add SUSE 9.1 too..i got this free distribution of linux from the digit DVD given out a while ago..i burnt the iso image onto a cd using nero and i was installing it on my system.everythin went smoothly until i was asked to create a root password as the admnistrator.To my surprise..nothin i typed in was appearin on the screen...it was as if the system simply didnt recognise the keyboard...I tried reinstallin and everything else u usually would try..nothin seems to work???any ideas whats wrong?the keyboard works perfectly well otherwise....
anna_don is offline
Old 06-12-2004, 08:00 PM   #2 (permalink)
FooBar Guy
GNUrag's Avatar
Default Re: Problem with SUSE 9.1
There's a separate section for queries related to linux in particular... Please check where you are posting....
http://web.gnuer.org
GNUrag is offline
