| Forum |
#1 (permalink) |
"The RaCaLaNGeL"©
2.when i click on add/remove software it gives an error unable to retrive software information....same for software update....what is the problem? on bouth counts i was logged in as root.
Without sorrows happiness would be boring! |
#2 (permalink) |
Commander in Chief
For NTFS follow this
http://stanton-finley.net/fedora_cor...otes.html#NTFS FC5 doest support NTFS by default due to legal issues. For the software manager, I think You need to do a Yum Update via terminal and then it should work fine.
Harsh J www.harshj.com |
#3 (permalink) |
"The RaCaLaNGeL"©
legal issues...hmmmmmmmm..but ubuntu mounts ntfs partition automatically...
can u please elaborate on yum update(new to FC%)....thanx ....
#4 (permalink) |
Commander in Chief
Read that link, from beggining
Red Hat has legal issues with MS on NTFS but it isnt explained at all why, its the only distro with no native NTFS support.
#5 (permalink) |
@Romeo, You should open the Terminal Window (similar to Command prompt in WIndows)
in Fedora & login as root ( su - ) & follow the instructions given by @Qwerty. Yum is the Package Manager in Fedora. It's used to install , update or remove packages. |
#6 (permalink) |
"The RaCaLaNGeL"©
@jguru
im familiar with terminal...what i wanted to knoe is hhow to use yum??(i know how ti use apt-get in ubuntu)
#7 (permalink) |
This is the syntax for Yum:
$ su - (Enter password) # yum -y install <package-name> If you want to work with a GUI Package Manager , type: # yum - y install yumex Now wait for the installation to complete. Yumex is the GUI frontend for Yum (like Synaptic in Ubuntu). You can install packages using Yumex. Yum Extender will be available from the menu 'Applications'->'System Tools' |
#8 (permalink) | |
String Phreak
/dev/hdb is ur second hardisk most probably. So u'll mount it by "mount -t ntfs /dev/hdbX /mnt"........where X is partition number! Identify ur parttion number corresponding to ntfs u wanna mount. If its second partition then X=2. For ur second problem dont use the add/remove programs thing.U'll face problem with it! Instead install all the repos first and use "yum update softwarename" ! http://stanton-finley.net/fedora_cor...ion_notes.html U'll find important repositories here in this site! |
#10 (permalink) |
18 Till I Die............
Why do you want to install deb in fedora? It isn't a good thing at all. You should get a rpm file for the same software.
http://www.bash.org/?258908 |
#11 (permalink) |
"The RaCaLaNGeL"©
actually i have a xmms .deb file wic was downloaded for ubuntu...just wondered if it can b put to use on fc5....i dnt have net at home...so can i download xmms with mp3 supporty and install it on fc5????
#12 (permalink) |
You can convert the '.deb' Debian package to RPM format using 'alien' package.
You shouldn't install '.deb' packages in Fedora!! That's an invitation for trouble!! |
#13 (permalink) | |
String Phreak
| Bookmarks |
| Thread Tools | |
| Display Modes | |
