Old 14-08-2006, 09:43 AM   #1 (permalink)
bharat_r's Avatar
Default half KDE half Gnome..help!!!
I was exploring SuSe 10.1 which had KDE
I ran the Search for files(Nautilus Search too)l which was located under
K-Menu->System->File manager
and from then on my desktop became half Gnome & half KDE & it looks bad...
See Pic:
How do I revert back to full KDE desktop..
Please Help!!
bharat_r is offline
Old 14-08-2006, 09:53 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: half KDE half Gnome..help!!!
I dont understand, what so GNOME in this? :\
Harsh J
www.harshj.com
QwertyManiac is offline
Old 14-08-2006, 10:02 AM   #3 (permalink)
left this forum longback
praka123's Avatar
Smile Re: half KDE half Gnome..help!!!
U can select keramik menu or any other from kde control centre that'll solve yor probs.
praka123 is offline
Old 14-08-2006, 10:04 AM   #4 (permalink)
bharat_r's Avatar
See the way the icons are...
& Konqueror is not being used to display folder contents when I click bharat's home on the desktop but uses it when I clik on the home icon next to K Menu
bharat_r is offline
Old 14-08-2006, 10:07 AM   #5 (permalink)
18 Till I Die............
lol harsh, give another look at the screen, he's task bar is KDE but his his desktop is GNOME desktop. Icon for home folder is a dead give away of gnome.
I have faced this with xfce too. Just open the terminal and type
 ps auxw | grep metacity
You will get two entries something like this
mehul    28954  0.0  1.2  15620  9472 pts/1    S    01:37   0:12 metacity
mehul    14266  0.0  0.1   2860   780 pts/0    S+   10:04   0:00 grep metacity
Now issue this command
kill -9 28954
Replace 28954 with whatever number you get which I have marked in bold in the output.
And, you Konqueror only under KDE, in fact I find it as the best file manager, it can do a lot more than what nautilius can do.
http://www.bash.org/?258908
mehulved is offline
Old 14-08-2006, 10:16 AM   #6 (permalink)
bharat_r's Avatar
I'm getting no such process:
bharat@linux-ycee:~> ps auxw | grep metacity
bharat 4560 0.0 0.1 2752 696 pts/1 S+ 10:16 0:00 grep metacity
bharat@linux-ycee:~> kill -9 4560
bash: kill: (4560) - No such process
& I got only 1 entry not 2....
bharat_r is offline
Old 14-08-2006, 10:33 AM   #7 (permalink)
have you tried killing and then restarting X?..or else rebooting?
that should solve your problem..
technomodel is offline
Old 14-08-2006, 10:35 AM   #8 (permalink)
bharat_r's Avatar
I'm not able to kill atatll..I says no such process.
Also tried restarting but it starts in KDE & immediately switches to Gnome
bharat_r is offline
Old 14-08-2006, 10:50 AM   #9 (permalink)
i dont understand...
u mean it is showing the KDE splashscreen and then going back to gnome desktop? or is it showing this mixed desktop again?
try
CTRL+ALT+BACKSPACE..
Old 14-08-2006, 11:04 AM   #10 (permalink)
OK post the output of
ps auxw
mehulved is offline
Old 14-08-2006, 11:33 AM   #11 (permalink)
JGuru's Avatar
@Tech_your_future, Looks like this guy (@Bharat) is running KDM & GDM simultaneously!!
I have never seen a Linux desktop like this!!
JGuru is offline
Old 14-08-2006, 10:31 PM   #12 (permalink)
El mooooo
eddie's Avatar
Your KDE session manager has saved Nautilus process and is autostarting it when you login to KDE. Instead of looking for metacity, look for nautilus using the command "ps auxw | grep nautilus" (without quotes) and then kill it.
Alternatively, you can pass the command "killall nautilus" (without quotes) to stop the nautilus process.
eddie is offline
Old 15-08-2006, 08:57 AM   #13 (permalink)
bharat_r's Avatar
Thanks eddie!!!
It worked & I've got rid of the ugly gnome!!
bharat_r is offline
Old 16-08-2006, 01:27 AM   #14 (permalink)
El mooooo
eddie's Avatar
lol!!! Beware dude...you might get assaulted by the GNOME lovers
eddie is offline
