| Forum |
#1 (permalink) | ||
my motherboard is asus A8N-E with the nforce-4 ultra chipset, and i am using the onboard audio. first i tried alsa to configure the sound card, but it couldnt detect it. then i downloaded the nforce chipset driver for linux from the nvidia website and from there i installed the audio driver. what the driver does is that it creates a kernel module called nvsound and inserts it into the kernel tree to be loade during booting. after creating the module some configurations needed to be done. here is what it said in th readme that accompanied the driver. Quote:
but i must have made a mistake, coz i cant play audio.. the module nvsound is loaded successfully during boot, but i whenever i try to play a an audio file..it says sound card not found.. what did i do wrong? |
#2 (permalink) |
all files in /etc/modprob.d are editable..u must have tried editing the /etc/modprob.conf.
i think u should add the lines in the file alsa-base of /etc/modprobe.d. also u should comment out the lines at the bottom of the file where it tries blocking third party modules from loading a sound driver. hope this helps.. post what happens. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
