Old 13-08-2006, 05:03 PM   #1 (permalink)
18 Till I Die............
Default No title bar when running compiz in AIGLX
I followed this link to install AIGLX http://www.ubuntuforums.org/showthre...=install+AIGLX. But now I don't get title bar in while running compiz.
I tried a couple of things to get it working like, download cgwd, start compiz from terminal as
 compiz --replace
But, all these methods have failed.
I am using onboard video memory. It is detected as savage.
Here's a screenshot
I am attaching my xorg.conf file too in case it's needed.
I can't get any effects of AIGLX working .
http://www.bash.org/?258908
mehulved is offline
Old 13-08-2006, 06:36 PM   #2 (permalink)
Default Re: No title bar when running compiz in AIGLX
hmmm...man I though YOU WERE the expert.
WE ARE THE BORG
YOU WILL BE ASSIMILATED
RESISTANCE IS FUTILE
borg is offline
Old 13-08-2006, 08:57 PM   #3 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Hehe.. even experts need help from time to time! I do have an idea about XGL.. Though after the conversation i had with you, i think most probably its the 16 bit colour depth that's keeping you from running AIGLX. Get a new gfx card
kalpik is offline
Old 13-08-2006, 09:06 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
You downloaded CGWD, but did you run it ? I know its kind of a foolish question but you have to run it and choose a theme to get the titlebars... so if you havent done that try it :]
Harsh J
www.harshj.com
QwertyManiac is offline
Old 13-08-2006, 09:11 PM   #5 (permalink)
kalpik's Avatar
He's already tried that Qwerty..
kalpik is offline
Old 13-08-2006, 09:34 PM   #6 (permalink)
Yes i tried all that. Actually I have been breaking my head over it since quite a few days.
I tried to edit lots of things in xorg.conf file and had to reconfigure my xserver lots of times but still no luck yet. It seems the 16-bit depth is the problem and I hopefully find the solution this week. But, I can't even rotate the cube, either.
mehulved is offline
Old 13-08-2006, 09:40 PM   #7 (permalink)
JGuru's Avatar
Yeah, @Kalpik is right. @Tech_your_future, your Graphics card is the culprit!!
Get a new good Graphics card. Your problem will be solved.
JGuru is offline
Old 13-08-2006, 09:52 PM   #8 (permalink)
Well let's see I might get one this week. But, then I won't have ubuntu. So, well I want to see if I can get it working on ubuntu. Or else I will be trying XGL on gentoo, atleast that's the plan.
BTW, I have none for now.
mehulved is offline
Old 14-08-2006, 12:51 AM   #9 (permalink)
left this forum longback
praka123's Avatar
Smile Re: No title bar when running compiz in AIGLX
Do u have "gnome-window-decorator &" running/restarted
more in gentoo wiki
Best O' LUX
praka123 is offline
Old 14-08-2006, 12:54 AM   #10 (permalink)
That would be cgwd, right? cgwd is running.
mehulved is offline
Old 14-08-2006, 12:58 AM   #11 (permalink)
Commander in Chief
http://www.compiz.net/topic-2252-window-decorator
Try that thing mentioned there maybe?
Harsh J
www.harshj.com
Old 14-08-2006, 01:09 AM   #12 (permalink)
OK That is compiz themer, now it's replaced with cgwd as you have seen with XGL, so it's no more applicable. Anyways I tried playing around with it, let me see if it works.
mehulved is offline
Old 14-08-2006, 01:52 AM   #13 (permalink)
El mooooo
eddie's Avatar
I have not tried AIGLX or XGL but looking at the screenshot, it seems that your window manager is crashing. Try running your window manager under gdb and see whether it is crashing or not. If it is, then you will at least have a definite path to walk on.
Also, why are you loading GLcore module? The thread you linked us to, suggests against doing it.
eddie is offline
Old 14-08-2006, 05:19 AM   #14 (permalink)
praka123's Avatar
Lightbulb Re: No title bar when running compiz in AIGLX
when i tried XGL in my 915GV+15" S/T monitor,it showed atleast a res of 1024*768 is needed...
praka123 is offline
Old 14-08-2006, 09:23 AM   #15 (permalink)
Well I did disable loading of GLCore after I made this post and later I even enabled 24bit depth. Still it's the same problem.
mehulved is offline
Old 14-08-2006, 10:44 AM   #16 (permalink)
you can try one thing..if u havent already done it..
go to this url and insert the calculated modeline under the monitors subsection in your xorg.conf. also update the screens subsection with the selected resolution.
of course..this will work only ur monitor is holding u back..which it might not as it is being detected..
hope this helps.
technomodel is offline
Old 14-08-2006, 08:56 PM   #17 (permalink)
kalpik's Avatar
Try to disable the reflection plugin from gconf-editor (apps->compiz->general->all screens->active_plugins)
kalpik is offline
Old 14-08-2006, 10:21 PM   #18 (permalink)
No it still doesn't help out.
mehulved is offline
Old 14-08-2006, 10:34 PM   #19 (permalink)
El mooooo
eddie's Avatar
Did you check the crashing part? Do you find anything unusual in Xorg logs?
eddie is offline
Old 14-08-2006, 10:40 PM   #20 (permalink)
I didn't get how to use gdb yet. I did a couple of tries but didn't get the right syntax. I haven't checked Xorg logs yet. I will check up on both as soon as I get enough time.
mehulved is offline
Old 23-08-2006, 11:52 AM   #21 (permalink)
Eddie I did as what you said
gdb compiz.real
run
The error message I get is
/usr/bin/compiz.real: No composite extension
Program exited with code 01.
mehulved is offline
Old 24-08-2006, 12:19 AM   #22 (permalink)
El mooooo
eddie's Avatar
Give output of "xdpyinfo | grep Composite" and your current Xorg.conf
eddie is offline
Old 22-12-2006, 11:19 PM   #23 (permalink)
Sorry for opening up an old thread. But, atlast I got 3D desktop working.
Beryl + AIGLX is working great on my new 7600GS card and a new 400W SMPS.
But, still I am having problems while running 3D as non-root. infact even if I give glxinfo command as non-root user, the Xserver crashes. Any ideas?
mehulved is offline
Old 23-12-2006, 12:09 AM   #24 (permalink)
Just another linux lover.
subratabera's Avatar
Here is something I found on Fedora Forum. Try it...
Troubles with AIGLX
the defaults xorg.conf's in FC6 should work, but things don't always work as they should. Here's a few tips that have helped others:
Add these parts to your xorg.conf (/etc/X11/xorg.conf) if you don't already have it:
In your "Device" section:
Option "AddARGBGLXVisuals" "True"
Option "DisableGLXRootClipping" "True"
Just have this somewhere, but not within another Section:
Section "DRI"
Group 0
Mode 0666
EndSection
It seems some of the default fc6 xorg.conf's don't have a "Module" section. If you're missing one, just leave it be like that. It will load the needed modules for AIGLX by default. (This applies to the two next points)
And this in your Module section, if you have a Module section:
Load "extmod"
If you're using ATi, the following in your "Module" section:
Load "dri"
Also try to delete that user & home folder then create a new user. this might solve your problem...
Today is a most unusual day, because we have never lived it before; we will never live it again; it is the only day we have.
(Registered Linux User #432737 - subratabera.blogspot.com)
subratabera is offline
Old 23-12-2006, 12:17 AM   #25 (permalink)
I have tried everything but the last line. And that's too dangerous. I have a lot f things lying in my ~ folder, don't wanna loose those and no space to move them. And I am on edgy not on FC.
mehulved is offline
Old 23-12-2006, 12:19 AM   #26 (permalink)
El mooooo
eddie's Avatar
After X crashes, check Xorg.0.log. Do you get something interesting or related?
__________
No need to delete...just create a new user and login with that. Your existing user files are non-readable to other users.
eddie is offline
Old 23-12-2006, 12:22 AM   #27 (permalink)
I checked Xorg.0.log but nothing worth noting that I found.
mehulved is offline
Old 23-12-2006, 12:57 AM   #28 (permalink)
El mooooo
eddie's Avatar
Ok then do one thing. Stop your X server totally. Now, login from a virtual console and start X server using startx. Do everything needed to crash X and see what output you get in the console. Also, now you should have something good in Xorg.0.log. Upload the log file, xorg.conf and errors (if any) you get on virtual console somewhere..lets see what it says.
eddie is offline
Old 23-12-2006, 01:04 AM   #29 (permalink)
Xserver isn't working as non-root user as of now.
And X doesn't crash due to some reason. Many times it crashes randomly after some period of time and other times it crashes when I type glxinfo or start anything that uses 3D.
Still I will try again and see what happens and post the logs.
mehulved is offline
