Old 10-08-2006, 02:44 PM   #1 (permalink)
adit_sen's Avatar
Default Ubuntu Installation Problems
Hi,
I've been trying for the last couple of days to install ubuntu (dapper 6.0.6.1), but I'm getting stuck. The live cd takes really long to boot up, and once it does, I choose install, but it doesnt seem to insatall. The CD drive keeps spinning and reading, there is definitely some HDD activity, but even after leaving it for more than an hour nothing happens!
I've even tried redownloading the ISO and burning it on a new CD, but the same problem presists.
Please Help...
cheers..
aditya
AMD 4400+ X2; Compaq Presario M2202TU; Dell Inspirion 500m; Windows Vista Ultimate
adit_sen is offline
Old 10-08-2006, 03:03 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Ubuntu Installation Problems
i think thers some problem with ur cd drive...... u need to clean the lens of ur drive
Pathik is offline
Old 10-08-2006, 03:08 PM   #3 (permalink)
adit_sen's Avatar
hmm...i was thinking the same thing. what's the best way to clean my drive?
adit_sen is offline
Old 10-08-2006, 03:11 PM   #4 (permalink)
DeSmOnD dAvId's Avatar
Are you trying to install from a Live CD??
AFAIK, you can only run Live CDs and caannot install until it is a Live+Install CD. Ubuntu does not provide Live&Install CDs.
"If God had wanted you to live he would not have created ME!"
Steam : Rrtry™ DeathMetal
My Blog : The Pandemonium (Latest Post : Where does music come from?)
Need new Electric guitar...help needed!!!
DeSmOnD dAvId is offline
Old 10-08-2006, 03:12 PM   #5 (permalink)
JGuru's Avatar
@Adit Sen, Are other bootable CDs of Linux distros or Windows O.S working fine
while booting using the CD drive? Is it a problem only with Ubuntu Dapper (6.06.1)?
Also the new version of Ubuntu you have downloaded may have bugs in it.
So better wait for some more months before the product is fully tested.
JGuru is offline
Old 10-08-2006, 03:21 PM   #6 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
why dont u create a temperary fat32 partition, save a iso of the disk and then install using 'askmethod'
Rollercoaster is offline
Old 10-08-2006, 03:49 PM   #7 (permalink)
adit_sen's Avatar
@desmond david - ubuntu's install & live cd are the one and same thing
@jGuru - haven't tried other distro's. cd drive works fine otherwise.
@RollerCoaster - can you provide a little more specifics on how to go about the askmethod?
adit_sen is offline
Old 10-08-2006, 04:26 PM   #8 (permalink)
Google Bot
Pathik's Avatar
@adit ubuntu has diff install and live cds.....
@desmond he s getting the option to install that means he is using a install cd.
Pathik is offline
Old 10-08-2006, 04:27 PM   #9 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
^^ Starting with dapper, they ship only one cd which is both live/install..
kalpik is offline
Old 10-08-2006, 04:51 PM   #10 (permalink)
Venom's Avatar
If its a DVD-RW you may have install issues but it wont hang, it will return an error instead!
From now on we are poison to you, that's why we call ourselves, the Venom!
Venom is offline
Old 10-08-2006, 04:57 PM   #11 (permalink)
adit_sen's Avatar
well can anyone suggest what i do?
adit_sen is offline
Old 10-08-2006, 06:25 PM   #12 (permalink)
left this forum longback
praka123's Avatar
Smile Re: Ubuntu Installation Problems
try this options as it works in debian etch(testing):
while booting with CD:
install libata.atapi_enabled=1
also read my link
CD Drives not detected ..seems a little weird
praka123 is offline
Old 10-08-2006, 11:26 PM   #13 (permalink)
adit_sen's Avatar
alrightey then...prolem solved!
During bootup, I chose install in safe graphics mode and it worked like a charm. Thanks for everyone's help.
Cheers
adit_sen is offline
Old 10-08-2006, 11:52 PM   #14 (permalink)
18 Till I Die............
Do you have a separate graphics card? If yes, which one? Just asking so I would know of potential problems if needed in future.
http://www.bash.org/?258908
mehulved is offline
