Old 09-08-2006, 10:58 PM   #1 (permalink)
plsoft's Avatar
Default Problem with Mandriva 2006
I can copy files from windows partition but when i try to write on the partitions it says "Access Denied". Even i can't change the permission properties. Please help.
plsoft is offline
Old 09-08-2006, 11:12 PM   #2 (permalink)
18 Till I Die............
Default Re: Problem with Mandriva 2006
Is the partition ntfs?
I am not so sure though that Mandriva 2006 has ntfs write access.
Also try adding uname=000 after defaults to the line where corrosponding to the partition in /etc/fstab.
http://www.bash.org/?258908
mehulved is offline
Old 09-08-2006, 11:33 PM   #3 (permalink)
plsoft's Avatar
Partition is Fat32
How do i go about this? Sorry m new to linux.
plsoft is offline
Old 09-08-2006, 11:35 PM   #4 (permalink)
Venom's Avatar
type,
sudo gedit /etc/fstab
and in the file that opens, do as T_y_F says.
From now on we are poison to you, that's why we call ourselves, the Venom!
Venom is offline
Old 10-08-2006, 12:03 AM   #5 (permalink)
OK do this
su
nano /etc/fstab
Now edit the line corrosponding to the ntfs partition. fdisk -l should help you there. Or maybe some other GUI tool.
Here's an example
/dev/hda1   /media/c_drive      ntfs   defaults,umask=000     0 0
mehulved is offline
Old 10-08-2006, 12:30 AM   #6 (permalink)
JGuru's Avatar
@Tech_your_future & @Venom, Mandriva Linux mounts Windows partitions automatically.
NTFS read/write support is available in Mandriva Linux 2006. NTFS write support was
available in Mandrake 9.2 itself!!
@Plsoft, here is the solution:
Mandriva Linux mounts the Windows paritions in the '/mnt' directory.
So to access C drive type, '/mnt/win_c', D drive , '/mnt/win_d' and so on.
The problem is you don't have write permission to the NTFS partition!!
Open the Terminal Window & type:
$ su -
(Enter password)
chmod -R 777 /mnt/win_c
$ exit
If it's other drive say E drive, then the command would be:
chmod -R 777 /mnt/win_e
That's all.This will solve your problem.
JGuru is offline
Old 10-08-2006, 12:46 AM   #7 (permalink)
plsoft's Avatar
sorry JGuru, still facing the same prob
plsoft is offline
Old 10-08-2006, 01:33 AM   #8 (permalink)
El mooooo
eddie's Avatar
Give us output of lsmod and "cat /etc/mtab" (without quotes) commands
eddie is offline
Old 10-08-2006, 01:51 AM   #9 (permalink)
plsoft's Avatar
/dev/hda9 / ext3 rw 0 0
none /proc proc rw 0 0
none /proc/bus/usb usbfs rw 0 0
none /sys sysfs rw 0 0
none /mnt/floppy supermount rw,sync,dev=/dev/fd0,fs=ext2:vfat,-- 0 0
/dev/hda1 /mnt/win_c vfat rw,umask=0022,iocharset=iso8859-1,codepage=850 0 0
/dev/hda5 /mnt/win_d vfat rw,umask=0022,iocharset=iso8859-1,codepage=850 0 0
/dev/hda6 /mnt/win_e vfat rw,umask=0022,iocharset=iso8859-1,codepage=850 0 0
/dev/hda7 /mnt/win_f vfat rw,umask=0022,iocharset=iso8859-1,codepage=850 0 0
/dev/hdd /mnt/cdrom2 udf ro,noexec,nosuid,nodev,users,umask=0022,iocharset= iso8859-1,user=sang 0 0
plsoft is offline
Old 10-08-2006, 02:13 AM   #10 (permalink)
El mooooo
eddie's Avatar
You did not give output of lsmod. Anyways, it is not needed anymore.
As suggested earlier, what you need to do is to edit your fstab file. How to go about is here:
1) Open a konsole/terminal window. Type "kdesu kate" (without quotes) and press enter. In the next window that opens, enter your root password.
2) A text editor will open which looks like notepad.
3) Go to File --> Open. Then in the "Location" field, type /etc/fstab and press enter.
4) The file that opens next, you need to edit the lines that look more or less like (not exactly the same)
/dev/hda1		/mnt/win_c	  vfat	      rw,umask=0022		0   0
Now you need to edit the umask values for every line containing "vfat" in it. Change umask=0022 to umask=0000
5) Save the file, reboot and try again.
eddie is offline
Old 10-08-2006, 03:03 AM   #11 (permalink)
plsoft's Avatar
Still the same prob, nways check this out.
lsmod
Module Size Used by
udf 83332 1
raw 6592 1
md5 3584 1
ipv6 234016 8
snd_seq_dummy 2532 0
snd_seq_oss 31136 0
snd_seq_midi_event 5696 1 snd_seq_oss
snd_seq 46960 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi_event
snd_seq_device 6828 3 snd_seq_dummy,snd_seq_oss,snd_seq
snd_pcm_oss 48960 0
snd_mixer_oss 16896 1 snd_pcm_oss
snd_ca0106 28420 0
snd_ac97_codec 83900 1 snd_ca0106
snd_pcm 79784 3 snd_pcm_oss,snd_ca0106,snd_ac97_codec
snd_timer 20548 2 snd_seq,snd_pcm
snd_page_alloc 8392 2 snd_ca0106,snd_pcm
snd 46116 9 snd_seq_oss,snd_seq,snd_seq_device,snd_pcm_oss,s
nd_mixer_oss,snd_ca0106,snd_ac97_codec,snd_pcm,snd _timer
soundcore 7008 1 snd
parport_pc 32612 1
lp 10024 0
parport 31976 2 parport_pc,lp
usblp 10976 0
ipt_IFWLOG 2788 1
ipt_psd 43428 1
ip_set_iptree 5544 2
ipt_REJECT 4256 4
ipt_LOG 6272 8
ipt_state 1312 7
ipt_pkttype 1184 4
ipt_set 1920 2
ipt_CONNMARK 1696 0
ipt_MARK 1984 0
ipt_ROUTE 4260 0
ipt_connmark 1216 0
ipt_owner 2432 0
ipt_recent 9292 0
ipt_iprange 1312 0
ipt_physdev 1744 0
ipt_multiport 2112 0
ipt_conntrack 1792 0
iptable_mangle 2016 0
ip_set_portmap 3840 0
ip_set_macipmap 3780 0
ip_set_ipmap 3872 0
ip_set_iphash 5924 0
ip_set 18876 11 ip_set_iptree,ipt_set,ip_set_portmap,ip_set_mac
ipmap,ip_set_ipmap,ip_set_iphash
ip_nat_irc 1824 0
ip_nat_tftp 1216 0
ip_nat_ftp 2560 0
iptable_nat 20212 3 ip_nat_irc,ip_nat_tftp,ip_nat_ftp
ip_conntrack_irc 70352 1 ip_nat_irc
ip_conntrack_tftp 3088 1 ip_nat_tftp
ip_conntrack_ftp 71408 1 ip_nat_ftp
ip_conntrack 40824 9 ipt_state,ipt_conntrack,ip_nat_irc,ip_nat_tftp,i
p_nat_ftp,iptable_nat,ip_conntrack_irc,ip_conntrac k_tftp,ip_conntrack_ftp
iptable_filter 2080 1
ip_tables 20416 20 ipt_IFWLOG,ipt_psd,ipt_REJECT,ipt_LOG,ipt_state
,ipt_pkttype,ipt_set,ipt_CONNMARK,ipt_MARK,ipt_ROU TE,ipt_connmark,ipt_owner,ipt_
recent,ipt_iprange,ipt_physdev,ipt_multiport,ipt_c onntrack,iptable_mangle,iptabl
e_nat,iptable_filter
via_rhine 19588 0
mii 4704 1 via_rhine
af_packet 16392 0
floppy 55444 0
video 14052 0
thermal 10920 0
tc1100_wmi 5092 0
processor 17876 1 thermal
fan 3172 0
container 3008 0
button 4848 0
battery 7460 0
ac 3268 0
ide_cd 37988 2
loop 14504 0
nls_iso8859_1 3680 5
nls_cp850 4480 4
vfat 10592 4
fat 45980 1 vfat
supermount 31956 1
via_agp 7584 1
agpgart 29032 1 via_agp
tsdev 5984 0
ehci_hcd 29192 0
uhci_hcd 29136 0
usbcore 108348 4 usblp,ehci_hcd,uhci_hcd
evdev 7648 0
ext3 124744 1
jbd 48568 1 ext3
cat /etc/mtab
The umask takes the default values after rebooting.
plsoft is offline
Old 10-08-2006, 09:17 AM   #12 (permalink)
El mooooo
eddie's Avatar
That is weird! Lets see your "cat /etc/fstab" then. Post the output of that command.
eddie is offline
Old 10-08-2006, 09:48 AM   #13 (permalink)
Eddie, the problem is with Mandriva. I vividly remember reading that Mandriva 2006 will overwrite a configuration file on next boot, if you do so manually.
So, it should have some kind of tool in the control centre or whatever it's called in Mandriva like YaST for Suse.
Here's something that can help http://doc.mandrivalinux.com/Mandrak...onf-intro.html .
mehulved is offline
Old 10-08-2006, 11:11 AM   #14 (permalink)
JGuru's Avatar
@Plsoft, Use Mandriva Linux 'Control Center' to configure things.Also you must use
'DrakPerm' wizard to configure File permissions in Mandriva Linux. Check this link:
http://doc.mandrivalinux.com/Mandrak.../drakperm.html
Choose the partition, where you have problem , & set the Permission as '777'.
This should work. @Tech_your_future, you are right. You configure everything in
Mandriva Linux through 'Control Center' using Wizards, not by manually editing
System files!!
JGuru is offline
Old 10-08-2006, 01:09 PM   #15 (permalink)
El mooooo
eddie's Avatar
Bleh! That frigin sucks! What else is left? A linux BSOD? Mandriva should invent such a thing...idiots.
eddie is offline
Old 10-08-2006, 03:40 PM   #16 (permalink)
plsoft's Avatar
@jguru how do i configure DrakPerm? Moreover, i can't find it so do i need to install it?
plsoft is offline
Old 10-08-2006, 07:21 PM   #17 (permalink)
Plsoft did you check the links supplied by me and JGuru? They have the information on how to find DrakPerm. It is already installed.
mehulved is offline
Old 10-08-2006, 08:32 PM   #18 (permalink)
JGuru's Avatar
@Plsoft, Open the Terminal Window & type:
$ drakeconf
(Enter Root password)
This will open up Mandriva Linux Control Center
You can configure everything in your System from monitor setttings, printer,
firewall, file permissions, Hardware, Installing or removing software etc.,
MCC is already installed, so you don't need to install it!!
This is how Mandriva Linux Control Center looks like
You have to do a bit of searching @Plsoft!!
JGuru is offline
Old 10-08-2006, 10:44 PM   #19 (permalink)
plsoft's Avatar
Actually i had already browsed thru control centre, just dat i didn't know it was the same as drakperm , sorry guys.
Will get back, let's c how i fare.
@JGuru- Have done everything u suggested, still the same prob. Really sorry to be a pain, pls bear.
plsoft is offline
